mothball smell in cedar chest
Forum topic by RickB posted 580 days ago 1549 views 0 times favorited 11 replies Add to Favorites Watch
View RickB's profile
RickB
48 posts in 1310 days
580 days ago
So, my wife acquired an old cedar chest used by a now-deceased family member. The thing was made by Sears a long time ago and had seen better days. My wife wants to refinish it and use it. My wife is doing the Lion’s share of the work and I am supervising.
One problem with the chest though is that there is a persistent mothball smell on the inside. The cedar lining has absorbed the smell. I’d like to get the smell out.
Any thoughts as to how I would get the smell out?
RickB
11 replies so far
View HorizontalMike's profile
HorizontalMike
4933 posts in 1084 days
#1 posted 580 days ago
The only thing I would suggest is to sand the interior with some 200grit. Wear a dust mask. No guarantees but worth a shot…
View ajosephg's profile (online now)
ajosephg
1720 posts in 1731 days
#2 posted 580 days ago
Maybe set it outside with the lid open exposing the inside to the sun?
-- Joe
View crank49's profile
crank49
2289 posts in 1141 days
#3 posted 580 days ago
Ozone treatment gets the smell out of smoke damaged belongings after a fire. Same process might work for the chest.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Jim Finn's profile
Jim Finn
1066 posts in 1092 days
#4 posted 580 days ago
A friend of mine had the same issue. (Who would put mothballs in a cedar trunk?) I gave him about 1/2 bushel of cedar chips from my planer that he put into the trunk for a few months. I am not sure how it worked though. I need to ask him. Just anogther attempt to correct this.
-- In God We Trust
View TJ65's profile
TJ65
1332 posts in 1219 days
#5 posted 580 days ago
try the sun if you can then if it is still there try sitting a large dish of Bi caronate of soda in there with the lid shut. It should gather up the smell pretty well after awhile. The other thing wold be to replace the smell with another – like lavender or camphor. That way you can keep it in there all the time. But I would try the Bicarb first.
good luck
-- Theresa, https://sites.google.com/site/tmj65treasure/
View DS's profile
DS
1820 posts in 590 days
#6 posted 579 days ago
I think Theresa is on the right track with the baking soda. Something to absorb the odor.
Not sure I’d subject this to direct sunlight because the heating cycles will cause movement in the wood.
Sanding likely won’t help as the odor is likely penetrated deeper than just the surface.
Rice is often used to dry things as it absorbs moisture—this might have a similar effect as sunlight without the heating cycles. You could layer uncooked dry rice on the bottom for a day. Turn the chest, layer the next surface. Patience would be key.
View renners's profile
renners
1892 posts in 1139 days
#7 posted 578 days ago
Eliminating odours is a breeze with Febreeze.
If nothing else works you could just leave it open for a few weeks and put scented lining paper in.
-- Do or do not, there is no try
View 000's profile
000
3352 posts in 786 days
#8 posted 578 days ago
You can leave it in an airy place for a couple years. Or you can just seal it all in with a couple coats of a good lacquer
I bought a huge bureau thing in a used furniture shop when I was in West Palm Beach for a year.
The shop was so lousy with sachets that I didn’t notice the smell in the wood of the bureau.
It clearly came from S Florida probably Miami South beach ‘coz it stank like a bad tranny Either that or the prior owner had both a penchant for big bottles of bad perfume and a bad case of parkensons.
I bleached it, hosed it, left it in the sun, shellacked it, even tried urethane.
The stink only stopped when I sprayed it with Lacquer.
-- When the moderator chooses sides, his site sucks.
View mrg's profile
mrg
483 posts in 1169 days
#9 posted 578 days ago
If sanding doesn’t work you could seal it and reline the inside with new cedar. You can get a closet kit at a big box store.
-- mrg
TopamaxSurvivor
13192 posts in 1846 days
#10 posted 578 days ago
It will go way if you leave it open, but it will take a loooooooong time.
View Schoey's profile
Schoey
23 posts in 1645 days
#11 posted 578 days ago
After doing a little research a while back I found out that cedar does little to ward off moths. Myth busted!
Ironically neither do mothballs. In “highly” concentrated amounts the chemicals in mothballs will kill moths.
Be careful if you sand as the chemicals in the mothballs are known carcinogens. I’d remove the cedar if it’s a lining.
