BS CT Resaw Blade- Tackling Gabon EBony- Best Blade? Laguna RS King? Lenox? Others? Help!!!
Forum topic by VillageBoy posted 581 days ago 886 views 0 times favorited 2 replies Add to Favorites Watch
View VillageBoy's profile
VillageBoy
49 posts in 590 days
581 days ago
Topic tags/keywords: bandsaw milling ebony wenge
I am currently narrowing down my choice for 5 HP Bandsaw (mostly for resaw). I will be cutting Ebony, Wenge, Afrormosia, and Padauk, but mostly ebony.
I am trying to figure out what carbide blade will cut the best an last the longest when tackling ebony day in and day out for the next several months.
Considering most of my boards are 3-4” x 12” x 71-73”, a good amount are 3-4” x 14-19” x 71-73”
I have looked at (price High to Low):
Lenox Armor CT Black 1.25” x .042” x 3” TPI
Laguna Resaw King CT 158” x 1.25” x 3 TPI
Lenox Tri-Master 1.25” x .042” x 3 TPI
Lenox SST Carbide 1” x .035” x 3 TPI
Lenox Wood Master CT
Super Cut- Woodsaver CI (Carbide Imbedded)
Any advice or recommendations? could really use the help. Thanks guys.
—- VillageBoy
2 replies so far
View jusfine's profile
jusfine
2152 posts in 1096 days
#1 posted 581 days ago
I have the Laguna resaw king on my Laguna HD16, it works very well resawing exotics.
I also use a carbide Lenox blade the rep gave me one time when he visited my shop about 8 years ago, that blade is marvelous on my 15” General and also has been used to resaw exotics. Not sure what the exact name of it was, but it is a fine blade and has remained on my saw all this time (may be the SST model).
You wouldn’t go wrong with either of those in my opinion.
All the Best!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Jon Spelbring's profile
Jon Spelbring
199 posts in 2424 days
#2 posted 580 days ago
I run a MiniMax MM20 with the Lenox Tri-Master for my resawing/veneer work. I’ve never had it bog or even slow down.
-- To do is to be
