Now that I nave a new Band saw do I need a scroll saw?
Forum topic by Blackie_ posted 10-20-2011 02:35 AM 2942 views 0 times favorited 20 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4883 posts in 2535 days
10-20-2011 02:35 AM
Topic tags/keywords: question bandsaw scroll saw
I just purchased a Griz GO555P 14” with riser and I already had in my inventory an old craftsman scroll saw which only excepts 3” blades I am pondering on replacing this one for a new larger model so my question now is that since I have the Band Saw do I really need a scroll saw?
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
20 replies so far
View jeepturner's profile
jeepturner
939 posts in 2815 days
#1 posted 10-20-2011 02:41 AM
Depends on what kind of work you want the scroll saw for. If you only want it for scroll work,(cutting outside curves) then the band saw would work. If you plan or want to do fret work, where you need to remove trapped material, the band saw wouldn’t work.
I have a band saw and a Dremel scroll saw and I use both.
-- Mel,
Blackie_
#2 posted 10-20-2011 02:57 AM
My main interest right now is crafting boxes, am already enjoying making them on the band saw so what does a scroll saw offer in that area? I’m guessing tighter turns, smaller boxes.
View Dusty56's profile
Dusty56
11819 posts in 3710 days
#3 posted 10-20-2011 03:02 AM
Haven’t even plugged my scroll saw in since getting a band saw , but I haven’t made any small projects either.
Only you know what your interests are and what tools you need or prefer to accomplish them with.
View Dallas's profile
Dallas
3599 posts in 2510 days
#4 posted 10-20-2011 03:06 AM
When used for boxes you can drill a hole in the appropriate spot, insert the scroll saw blade, then connect it to the saw and cut the inside area out.
You can’t do that with a band saw unless you have a blade welder on hand, and it’s still a PITA. I detest cutting and welding a perfectly good blade for one hole!
View richgreer's profile
richgreer
4541 posts in 3097 days
#5 posted 10-20-2011 04:39 AM
I own a relatively good (and somewhat expensive) scroll saw that I never use. I have no interest in typical scrolling work. On those few occasions that I want to cut out an internal piece, I grab my handheld jigsaw that serves me well enough.
IMO – real scroll saws are only for those who what to do intricate scrolling work. That’s not me.
View Pdub's profile
Pdub
924 posts in 3202 days
#6 posted 10-20-2011 05:00 PM
You’ll need to decide how intricate you want to get. If you are not going to get into; as Rich put it “intricate scrolling work” then I wouldn’t buy another scroll saw.
-- Paul, North Dakota, USAF Ret.
View HorizontalMike's profile
HorizontalMike
7758 posts in 2936 days
#7 posted 10-20-2011 05:27 PM
I’ve had my old 16” Delta scroll saw for +15yr when I bought my 14” Rikon BS. I STILL used the scroll saw when cutting ~4in holes in 3/4in ply for my DC separator. Can’t do that on a BS.
My advice it KEEP IT because at some point you will still need it.
Blackie_
#8 posted 10-20-2011 06:56 PM
Actually I think I do want to scroll :)
View Jim Finn's profile
Jim Finn
2657 posts in 2944 days
#9 posted 10-20-2011 11:58 PM
I have a band saw and two scroll saws and use all of them. I do double bevel ihnlays with the scroll saws and resaw a lot with the band saw. The band saw cuts a lot faster than the scroll saw and is better for cutting streight lines but the finish on the cut of a scroll saw is far and away much better than the finish of a band saw cut. I use a scroll saw to make these boxes band saw will not work with this type of box:
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
Blackie_
#10 posted 10-21-2011 12:04 AM
Thanks Jim, that’s the kind of stuff I’d like to do as well. I’m hoping santa might have one for me. :)
View blackcherry's profile
blackcherry
3338 posts in 3845 days
#11 posted 10-21-2011 12:25 AM
Consider the Carter Stablizer here a video of the unit….http://www.carterproducts.com/product.asp?product_id=482&cat_id=14 ....This unit will convert your bandsaw to a scroll saw in a mater of minutes. It meant to be used with 1/4 inch blades and smaller the video will show you more, hope this helps…Blkcherry
View Elizabeth's profile
Elizabeth
817 posts in 3166 days
#12 posted 10-21-2011 12:47 AM
The stabilizer still won’t let you do inside cuts for fretwork, though.
blackcherry
#13 posted 10-21-2011 02:30 AM
Your absolutely right Elizabeth.
View gfadvm's profile
gfadvm
14940 posts in 2713 days
#14 posted 10-21-2011 04:47 AM
+1 for the Carter stabilizer except for the inside cuts. It allows very tight cuts and really speeds blade changes (don’t have to readjust upper and lower guides every time you change blades).
Blackie_
#15 posted 10-21-2011 05:06 AM
I’ll give that carter a look at, may have to give them a call, I didn’t see one for the grizz 14” but they did have one for the 16” and it looked like it would fit mine.
