Drill chuck run-out
Forum topic by FoxMountainWoods posted 10-19-2011 10:46 PM 1405 views 0 times favorited 6 replies Add to Favorites Watch
View FoxMountainWoods's profile
FoxMountainWoods
30 posts in 2707 days
10-19-2011 10:46 PM
Hi There folks,
I just bought a drill chuck and arbor to fit the tail stock of my lathe. Problem is that the chuck has about 1/16th of an inch run-out. I checked the arbor, no run out there, definitely in the chuck. Is there any way to fix the run out in the chuck? When I drill, only one side of the bit does the cutting and my holes are about 1/16th larger than they should be.
Thanks,
SCOTT
-- Scott Hubley - Nova Scotia, Canada - http://www.foxmountainwoods.com
View Bill White's profile
Bill White
5054 posts in 4080 days
#1 posted 10-20-2011 12:24 AM
Where did ya buy it? I’d be takin’ it back super quick. 1/16” is WAY too much runout.
Bill
-- bill@magraphics.us
FoxMountainWoods
#2 posted 10-20-2011 12:55 PM
That would be the other option – I got it at Busy Bee Tools (Canadian). The gas to get there is more than the chuck is worth though
View Minorhero's profile
Minorhero
373 posts in 2724 days
#3 posted 10-20-2011 01:15 PM
Sometimes the chucks don’t get seated all the way. Before you give up on it take a hammer, withdrawl the teeth all the way into the chuck, and lightly tap the chuck into the headstock. You don’t want to drive it in so far it never come out. But you do want to hit it so that it reseats itself if it is stuck on something.
This also works on drill presses that have morse taper chucks.
FoxMountainWoods
#4 posted 10-22-2011 12:14 PM
Hammering it in did help fix some of the problem – It is still a bit off just by looking at it by eye – I will try drilling a couple holes this weekend and see how it works. Thanks.
View Fuzzy's profile
Fuzzy
298 posts in 4108 days
#5 posted 10-23-2011 04:29 AM
Do the tips of the jaws all align in the same plane ??? It’s possible one jaw got misaligned when it was assembled. They are not at all difficult to disassemble & check.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
FoxMountainWoods
#6 posted 11-11-2011 04:58 PM
Just to fill you guys in, I could reduce the runout but could never fix it. Ended up taking the Busy Bee chuck back and getting a more expensive one from Lee Valley. Seems to be alright, a bit of run out still but nothing I can`t deal with.
SCOTT
