Eggbeater Hand Drill Bit Size
« back to Hand Tools forum
Forum topic by ColdAudio posted 584 days ago 844 views 0 times favorited 5 replies Add to Favorites Watch
View ColdAudio's profile
ColdAudio
17 posts in 655 days
584 days ago
I currently have an eggbeater that can hold up to 5/16” drill bit.
Can anyone recommend one that can hold up to 3/8” or larger?
Also, do any of you guys use brad point bits with an eggbeater drill? For some reason, I’ve been thinking they might be difficult to crank by hand because they are so aggressive.
5 replies so far
View Brett's profile
Brett
603 posts in 855 days
#1 posted 583 days ago
You might look into breast drills if you want to use bits larger than 3/8”.
-- More tools, fewer machines.
View bookworm's profile
bookworm
39 posts in 1493 days
#2 posted 583 days ago
You might consider moving to a brace once you reach the half inch or so territory.
-- "I asked my wife if I look dorky in the video below where I'm planing that long piece of wood. Her reply: "It's all dorky."" - Mitch Roberson from his blog Furnitude
ColdAudio
#3 posted 583 days ago
Hmm, I’ve got 3 braces and a bunch of unmarked bits, I guess I’ll have to figure out what size everything is. Haven’t used any of it yet.
I was hoping to be able to use a 3/8” and 1/2” with 3/8” shank drill bits I have :)
View Brit's profile
Brit
4204 posts in 1015 days
#4 posted 583 days ago
A brace is definitely the way to go when you get to 3/8” and above. Any eggbeater is going to struggle to perform well or more to the point, you will :-) Eggbeater’s can’t generate enough torque. A brace with an 8” or 10” sweep will work much more smoothly.
-- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it.
View maljr1980's profile
maljr1980
171 posts in 628 days
#5 posted 583 days ago
i have a makita with a 1/2 inch chuck :)
