accuride drawer slides
Forum topic by sarahss posted 10-19-2011 02:39 PM 1218 views 0 times favorited 3 replies Add to Favorites Watch
View sarahss's profile
258 posts in 2579 days
10-19-2011 02:39 PM
I have some accuride side mount drawer slides with ball bearings. Is there any reason that I can’t just flip them on their sides and mount them to the underside of a drawer and attach the mating part to a wooden rail under the drawer?
3 replies so far
View Roz's profile
1699 posts in 3716 days
#1 posted 10-19-2011 03:39 PM
Hi Sarah, I have done it and it will work. I have some that have been in service over 5 years without trouble. However, they are not engineered to be used in that position. If you do not approach the rated weight limit for the slide you should be ok. The bottom mount slides are much better.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
View DLCW's profile
530 posts in 2584 days
#2 posted 10-19-2011 06:36 PM
I asked Accuride this exact same question and their response was that they have no load support numbers for doing this to their slides. So, your mileage will vary as to what the drawer will be able support, weight wise, before coming apart.
-- Don, Diamond Lake Custom Woodworks - - "If you make something idiot proof, all they do is make a better idiot"
View DS's profile
2865 posts in 2350 days
#3 posted 10-19-2011 06:48 PM
Ditto what Roz said. They’re not designed to carry a load this way.
Accuride actually makes a glide for this configuration. They call it a pantry glide or something like that. It costs a bit more, but they work really well.
