Table saw set up troubles
Forum topic by eddymas posted 10-18-2011 06:37 AM 836 views 0 times favorited 3 replies Add to Favorites Watch
View eddymas's profile
eddymas
2 posts in 2532 days
10-18-2011 06:37 AM
I have a Jet Proshop saw and having trouble setting up my table saw. I’ve done all the squaring with the fence and miter gauge slot. When I make a rip cut, the end of the cut always seems to get tapered. I think I might be getting some deflection from the fence but not sure.
I’ve changed:
- the insert with a clear 1/2” acrylic zero clearance insert
Has anyone dealt with the same issue? Any suggestion on how to fix this?
3 replies so far
View tom427cid's profile
tom427cid
294 posts in 2590 days
#1 posted 10-18-2011 08:17 AM
Sounds like the back side(outfeed) of the fence is to tight. You should have .003-.005” more there than at the infeed.
Hope this helps.
tom
-- "certified sawdust maker"
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3405 days
#2 posted 10-18-2011 10:52 PM
If the top is not aligned with the blade, the fence could be off, causing your problem.
If you have the manual, look at page 17. It will explain how to adjust this. If not, here is the link to see it
http://content.wmhtoolgroup.com/manuals/708482K_m.pdf
Then recheck your fence alignment. If you need more help, PM me and I’ll give you a phone # to call. I am a Jet dealer, so maybe I can help.
-- http://shepherdtoolandsupply.com/
eddymas
#3 posted 10-19-2011 05:05 AM
Thanks for the replies. I’ll put your suggestions to the test.
