Digital Angle Gauges...ohhh my which one??
Forum topic by handystanley posted 585 days ago 1766 views 0 times favorited 23 replies Add to Favorites Watch
View handystanley's profile
handystanley
152 posts in 1085 days
585 days ago
I am considering getting a digital angle gauge that I can validate that I am spot on when setting the bevel angle on my table or miter saw correctly.
From what I understand there are three reliable models to choose from:
1. Wixey Digital Angle Gauge
2. Beall Tilt Box
3. Dixie Digital Angle Gauge
I have read that the Wixey goes through battries…any comment? Otherwise, any comments or recommendations…(geessh…when doesn’t a lumberjock not have a comment or a recommendation???)
Thanks.
-- "Projects beget projects and projects beget the need to buy new tools and that is what the cycle of life is all about." Stan Pearse, Novato, CA
23 replies so far
View ajosephg's profile
ajosephg
1723 posts in 1733 days
#1 posted 585 days ago
I’ve had a Wixey for several months, but haven’t used much yet, but it’s still on original batteries.
I’m willing to wager that battery life on all of the electronic gauges is pretty much the same as I think they share the same circuit design.
-- Joe
View syenefarmer's profile
syenefarmer
332 posts in 1252 days
#2 posted 585 days ago
Wixey or Beall are known to be dependable and accurate. I have been happy with my Wixey but they do have a constant drain on the battery even when powered off. That issue can be solved by simply removing the battery after each use.
View Fuzzy's profile
Fuzzy
251 posts in 2160 days
#3 posted 585 days ago
Had the Wixey … it died just out of warranty … replaced it with a BEALL … never had a problem with it in 3 or 4 years.
My vote goes to BEALL
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View tenontim's profile
tenontim
2129 posts in 1916 days
#4 posted 585 days ago
Have a Wixey. Mine died about 1 month from the expiration of the warranty. The company replaced it with a new one muy pronto. Also have their digital height gauge on my planer.
-- Tim-- http://www.tmuli.com
View jobott's profile
jobott
27 posts in 1534 days
#5 posted 585 days ago
I’ve had the Beall for a couple of years so far, works great and still on the original battery. Nice construction and operation as well.
-- Joe B
View wingate_52's profile
wingate_52
204 posts in 742 days
#6 posted 585 days ago
Wixey, really useful for setting plane blade sharpening angles.
View Cato's profile
Cato
642 posts in 1484 days
#7 posted 585 days ago
My Wixey I have had for over a year and still on original battery. Very handy little tool.
View jeepturner's profile
jeepturner
896 posts in 964 days
#8 posted 585 days ago
Bought a Wixey on sale from Wood Craft a month ago. Have not had any problems, but it has made life in the shop a lot easier. If this one goes bad, I would still buy another, it has certainly saved me more than the thirty bucks I spent to purchase it.
-- Mel
View richgreer's profile
richgreer
4474 posts in 1247 days
#9 posted 585 days ago
I take a different approach to setting the angle of my miter. I use the Wixey digital tilt gauge with the magnets. This is a great tool for setting the blade tilt angle. It can also be used for the miter.
I place the front of the miter face down on a flat surface with the track hanging down off the edge of the flat surface. Then, I put the Wixey on the back of the miter and zero it. Then, I put the miter on the side of the track with the magnets and set the angle desired. Works great!
View 000's profile
000
3352 posts in 789 days
#10 posted 584 days ago
I had to modify my beal so that it was actually square. The sides were not square to the base. None of the sides were actually flat. They were painted. Painted?? Friggin PAINTED???? Yup painted.
I can’t understand any one who produces a device that is supposed to be accurate to 2 decimal places while also painting the reference surfaces.
That said: I know people with very spendy digital angle gauges who report that they get different measurements of the same angle depending on battery condition.
-- When the moderator chooses sides, his site sucks.
wingate_52
#11 posted 584 days ago
Itake my battery out of the Wixey when not using it. Used it today, worked well.
View Paul Stoops's profile
Paul Stoops
276 posts in 733 days
#12 posted 583 days ago
I have the Wixey (original model) and an IGaging angle cube. I like the IGaging better because it has a 9v battery—which should translate into longer battery life than the CR2032 button cells. That said, Wixey has come out with an improved model that uses two AA batteries—but the price is higher.
-- Paul, Auburn, WA
View David Grimes's profile
David Grimes
2114 posts in 812 days
#13 posted 583 days ago
Get this one while it’s on sale (50% off). I just did.
http://www.rockler.com/product.cfm?page=24525&utm_source=NL&utm_medium=email&utm_campaign=V2027
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
handystanley
#14 posted 583 days ago
@David Grimes: The unit you mentioned above will not help in setting the bevel angle of a blade…the extentions are too long.
handystanley
#15 posted 583 days ago
I see that Beall has come out with a new digital angle gauge:
http://www.bealltool.com/products/measuring/tiltbox.php
