Square sides on old Stanley Bailey planes?
« back to Hand Tools forum
Forum topic by Brett posted 10-17-2011 08:00 PM 1434 views 0 times favorited 6 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2705 days
10-17-2011 08:00 PM
I’m considering buying and refurbishing an old Stanley Bailey plane to use as a dedicated shooting plane (my other user-planes have irons with slight cambers, and I’d like my shooting plane to have a straight iron).
Are the sides of any of the old No. 5, No. 5 1/2, or No. 6 planes machined square to the base? I know that I could cant the plane iron so the cutting edge is square to the base, but I’d prefer to use a plane with a side that is square as well. Any thoughts?
-- More tools, fewer machines.
View TheDane's profile
TheDane
5438 posts in 3685 days
#1 posted 10-17-2011 08:08 PM
Brett—Generally, when they left the factory they were square. But they can, over time and with use/abuse, wind up out of square.
I had a local machine shop (that kind rebuilds auto engines) square up the #5 I use on my shooting board. They also flattened the sole and and produced a near mirror-polish on it … I think they charged me $20 to do it.
—Gerry
Brett
#2 posted 10-17-2011 08:20 PM
Twenty bucks? That’s worth looking into. Thanks.
TheDane
#3 posted 10-17-2011 08:25 PM
It only took a few minutes to do, and he only took off a few thousandths. The only problem with that plane now is it is too pretty to use!
—Gerry
View Dan's profile
Dan
3630 posts in 2902 days
#4 posted 10-17-2011 08:25 PM
You can lap/flatten the sides of the plane just like you would the sole using some sandpaper that is attached to a flat surface. I have done this a number of times and found that the sides take far less time to flatten then the soles do.
The sides would have to be way off to really make a noticeable effect when using with a shooting board.
I would also suggest the 5 1/2 or 6 for a shooting plane. The #5 will work but the extra mass and blade width of the 5 1/2 and 6 make them a little better for shooting IMO… Those are the two sizes I use most for shooting.
-- Dan - "Collector of Hand Planes"
View Brit's profile
Brit
7385 posts in 2864 days
#5 posted 10-17-2011 08:36 PM
Ditto what Dan said. I’ve found that most old Baileys are out of square, but it is only worth doing for a plane that will be used for shooting.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
Brett
#6 posted 10-17-2011 08:59 PM
Some of my Stanley Bailey planes were both out-of-square and “out of flat”. In other words, not only were the sides not at 90 degrees t the sole, but the top part of the “hump” on the sides also curved inwards more than the base. I tried to lap the sides as I did the base, but because the tops curve inwards, it would have required removing too much metal to truly make the sides either square or flat.
