Cleaning Bandsaw Blades?
Forum topic by gfadvm posted 583 days ago 1621 views 0 times favorited 14 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
6635 posts in 859 days
583 days ago
Topic tags/keywords: bandsaw blade
How do you all do this? My blades are 131 1/2” long and I have not found a way to get the pitch/grunge off without spending a lot of time. There has to be a better way!
14 replies so far
View BarryW's profile
BarryW
1013 posts in 2076 days
#1 posted 583 days ago
I got a can of blade cleaner from Grizzley….spray on, wipe off…..it does take some time, but there is a preparation the removes gunk fairly quickly….
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View DaleM's profile
DaleM
800 posts in 1553 days
#2 posted 583 days ago
I have used automotive engine cleaner/degreaser. I just spray it on while I turn it by hand and then wipe it off. I was worried at first that it might damage the tires or something else, but so far it doesn’t seem to have damaged anything. I have tried two different kinds and they both worked about equally well for removing pine resin. One is Pro Formula 409 automotive degreaser and the the other is Castrol Super Clean.
-- Dale Manning, Carthage, NY
View rance's profile
rance
3856 posts in 1329 days
#3 posted 583 days ago
Same method as a TS blade. Coil them up(like they come to you when you buy them) so they’ll fit in a large bucket.
View bluekingfisher's profile
bluekingfisher
808 posts in 1149 days
#4 posted 583 days ago
Auto carb or brake cleaner will also suffice
-- No one plans to fail, they just, just fail to plan
View blackcherry's profile
blackcherry
2903 posts in 1992 days
#5 posted 583 days ago
Fold the blade and use a shallow pan like a oil pan or cut down 5 gallon pail. A splash of Lestoil degreaser and hot water let set for 15 min and wipe of with soft cloth, non toxic and a breeze to clean.
View 000's profile
000
3352 posts in 786 days
#6 posted 582 days ago
five pound hand sledge.
I lube my blades from time to time with wax and mineral oil melted together. Seems to keep wood sugars and goo from building up.
-- When the moderator chooses sides, his site sucks.
gfadvm
#7 posted 582 days ago
I’m not too good at coiling my blades up despite watching several videos on how to do it so not sure I can get them coiled tight enough to fit in the pan I clean TS blades in. 5 pound sledge??? The wax does help a lot and also seems to make cut easier but Bois de Arc will gum up a blade regardless.
View Jimbo4's profile
Jimbo4
710 posts in 932 days
#8 posted 581 days ago
I spray original Pam on the blade. It helps. To get off the stuck on stuff, I use a green scratcher pad soaked
in 409 – seems to work pretty good.
-- *Arachnoleptic*: The frantic dance performed just after you've accidently walked through a spider web.
View cmm's profile
cmm
5 posts in 1906 days
#9 posted 581 days ago
I coil the blade into the 3 coils all the books show you to do. Then put it into a plastic container with mineral spirits. Let sit for a few minutes, then brush with a soft copper brush. Usually comes clean with little effort and is reasonably fast. I also use Pam on the blade, which helps with many woods. I had a particularly resinous pine that really gummed up blades and tried blade cleaner. Finally tried the mineral spirits, which requires much less elbow grease!
View 000's profile
000
#10 posted 581 days ago
screw the videos.
Hold the band in one hand (who cares which way the teeth point)
Step on the band with one foot
Rotate the hand in the same direction twice – as you do this the band will coil and you’ll have to bend over.
That’s it.
View ChunkyC's profile
ChunkyC
849 posts in 1423 days
#11 posted 581 days ago
Supper Clean for me.
cr1 has it right, step on the blade and twist is the easiest and safest, IMHO, way to coil them up.
Here's how to do it:
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
View Bill White's profile
Bill White
2604 posts in 2129 days
#12 posted 581 days ago
Use Arm & Hammer WASHING SODA (not baking soda). Warm water to dissolve, soak for a few minutes, brush if needed, rinse, wipe off. Biodegradeable, no odor, non toxic. What else would ya want. Oh, it’s not expensive either. I use it on all my blades.
Simple Green also works well. 50/50 dilute. Same process.
Bill
-- bill@magraphics.us
gfadvm
#13 posted 581 days ago
Thanks for the input. CR1, If I need more/smaller coils just keep rotating my hand until it’s small enough to fit in my pan? I can get the smaller blades coiled, it’s the 1” resaw that I have trouble with.
View DS's profile
DS
1820 posts in 589 days
#14 posted 580 days ago
gradvm: Amen to the 1” resaw blade! I usually feel foolish when it snaps back and whips me upside the head.
I can get the smaller blades coiled up but the big ones usually end up dangling from the end of my lumber rack uncoiled.
Any suggestions on how to coil them up without feeling like I just lost a WWE wrestling match would be appreciated! :-D
