What is the best sandpaper to use for lathe sanding ?
Forum topic by David Grimes posted 10-16-2011 10:04 PM 4691 views 0 times favorited 9 replies Add to Favorites Watch
View David Grimes's profile
David Grimes
2078 posts in 2606 days
10-16-2011 10:04 PM
I’d sure appreciate any advise on your recommended type, brand and source of sandpaper (rolls?) for sanding things on the lathe. I just hate guessing and later wishing I’d asked others what the best is.
I come up with this ($22.49 shipped), but then Rockler and others have similar.
Are some better than others ?
Thanks.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
9 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3527 days
#1 posted 10-16-2011 11:20 PM
I don’t have a lathe, but my go to source for sandpaper in general s Klingspor.
They also have helpful and knowledgeable humans that will talk to you on the phone to help dig through all the choices they offer.
-- Joe
View pariswoodworking's profile
pariswoodworking
386 posts in 2451 days
#2 posted 10-16-2011 11:49 PM
I like mesh sandpaper from penn state industries. http://www.pennstateind.com/store/PKMESHKIT.html It is reuseable and easy to clean. I also like micromesh from woodturningz for really fine sanding. http://woodturningz.com/Finishing_Supplies.aspx (9-Piece Micro-mesh Finishing Set). They also have regular rolls like the ones you posted for just a little bit more. These are mostly for pens. What are you turning?
-- Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. -- Albert Einstein
View Bernie's profile
Bernie
422 posts in 2803 days
#3 posted 10-18-2011 05:21 AM
I’m not cheap… but I use my used paper from my portable sander. I just cut it in strips and it works just fine. I never thought of buying special strip paper for the lathe. If your paper works well for you, then use it. Now that I know about it, I might check it out and maybe even buy some, but for now my recycled paper works just fine.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
David Grimes
#4 posted 10-18-2011 05:34 AM
@Bernie, I am cheap as long as it gets done right. That’s a great idea. I have a bunch of them (round and iron shaped) that still have some life in them and have the good hook and loop back on them, too. I’m gonna try cutting them into strips. I bet they’ll do great. Thanks.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3401 days
#5 posted 10-18-2011 05:51 AM
@David,
You can even put some velcro on you fingers and palms to attach the hook & loop leftovers and grab that sucker in the lathe for sanding. :-)
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
David Grimes
#6 posted 10-18-2011 05:59 AM
SANDING MITTS ! Thank you Thank you Rex. Jackpot !!!
Warning: Do not touch your Velcro shoes or trousers’ fly with the Velcro Sanding Mitt while operating machinery. We are not responsible for the many positions you may find yourself in with this product if this warning is not heeded. Do not let children use this item playing a mixture of “Twister” and “Simon Says” as injury and ridicule may result.
Roger Clark aka Rex
#7 posted 10-18-2011 06:06 AM
@David:
Your forgot to add the Surgeon General’s warning:
Exercise extreme bladder control when using the Sanding mitt.
...... and from the KY people: please remove mitt before retiring.
David Grimes
#8 posted 10-18-2011 06:26 AM
lol @ Rex
Aren’t you glad we’re not “the KY People” ? Though I suppose it’s better than ” Hi, I’m the Messengill Quality Guru” or the “Depends Six Sigma Black Belt”.
View interpim's profile
interpim
1170 posts in 3424 days
#9 posted 10-18-2011 06:39 AM
I’ve always used sheets of paper that I tear off little strips… I usually get about 8 or so strips per sheet. Also, I have found the slower you spin the lathe when sanding the better the finish. High speeds heat up the paper and leave sanding marks that are difficult to remove. It also ruins the Micromesh that Paris mentioned before.
-- San Diego, CA
