GO555X
Forum topic by Howie posted 10-16-2011 06:38 PM 1597 views 0 times favorited 13 replies Add to Favorites Watch
View Howie's profile
Howie
2656 posts in 2952 days
10-16-2011 06:38 PM
Has anyone converted theirs to 220 and was it worth it?
-- Life is good.
13 replies so far
View Steven H's profile
Steven H
1117 posts in 3089 days
#1 posted 10-16-2011 07:06 PM
First of all do you have 220?
View GMman's profile
GMman
3902 posts in 3726 days
#2 posted 10-16-2011 07:46 PM
COPY/PASTE…...from the web.
I have a Grizzly G0514X bandsaw and have had excellent luck with it. I really shopped around (Jet, Delta, Rikon, Powermatic) and found that it had the best features.
Some of Grizzly’s tools are junk. This saw is solid and has functioned reliably. I cut corbels, arches, and brackets from heavy timber. I re-wired my saw to run on 220V, and it sails through the thickest timbers I can throw at it. It is easy to tune and runs quietly. The saw is awesome for resaw work as well.
The only problem I had was with the motor starter. I was starting and stopping the saw well over 60 times an hour, and it was eating starters. I figured out that it is just best to leave it running so the starter isn’t overworked, and now I limit myself to probably 20-30 starts per hour. Grizzly took great care of me with replacement parts in a hurry. They are great to deal with.
Howie
#3 posted 10-16-2011 08:55 PM
@steve: Yes I have 220 right next to the saw. All I need to do is swap the wiring and plug.
Gman: I don’t use mine as much as you do. It’s been awesome though. Just thought I might swap it to 220 if it was worth it.
-- Life is good.
View syenefarmer's profile
syenefarmer
492 posts in 3109 days
#4 posted 10-16-2011 10:26 PM
The only real advantage to having it wired 220V over 110V is that the bandsaw will more than likely be on a dedicated service with 220V and share the line with other things on 110V. If more power and cheaper to run are what you’re looking for, 220V will give you neither.
Howie
#5 posted 10-16-2011 11:13 PM
Thanks for all the replys. Frankly it doesn’t seem worth it.
-- Life is good.
TopamaxSurvivor
18293 posts in 3704 days
#6 posted 10-17-2011 08:33 AM
Unless you have a noticeable hesitation when you start the motor, you will not gain a thing.
View Paul Stoops's profile
Paul Stoops
348 posts in 2590 days
#7 posted 10-17-2011 05:59 PM
I have this same saw and wired my shop with a 220VAC outlet specifically for the bandsaw. However, I haven’t gotten around to making the changeover yet, altho I do plan to do so in the near future. One factor that hasn’t been mentioned is that operating tools on 220VAC does a better job of balancing the current draw between both sides of the line. As a side note, when I changed my 1 1/2HP tablesaw motor from 110VAC to 220VAC, I noticed that the saw motor came up to speed almost instantly.
This tool has a 1 1/2HP motor rated at 15A 120VAC, which is 75% of a 20A circuit capacity rating. I personally don't like to operate 110VAC circuits any higher than that. This motor would only pull 7.5A 220VAC, which would be distributed equally across both legs of the circuit. Also, as mentioned before, there may be other tools or lighting on the same 110VAC circuit, using some of the available capacity of that circuit.
I also agree that there is no power cost advantage to using 220VAC, since power is charged on the basis of kwh consumption.
If I had the choice, I would opt to use the 220VAC circuit.
-- Paul, Auburn, WA
TopamaxSurvivor
#8 posted 10-17-2011 08:38 PM
That is an example of a noticeable hesitation. The problem is starting too big a motor on a circuit with too much voltage drop caused by the starting in rush current.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2791 days
#9 posted 10-18-2011 06:18 PM
When I had my house built, I had a dedicated 220v/20Amp dedicated service line just for this purpose. I have
converted my TS, BS, and lathe all to 220V – piece of cake. They all start easier, run cooler, and use less amps
than a 110. I have only one outlet, so when I want to use a tool, I just unplug and replug – no big deal ! I also
like the idea that I can switch off the dedicated circuit breaker to keep “little” prying hands out of the workings.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View rance's profile
rance
4258 posts in 3189 days
#10 posted 10-18-2011 06:30 PM
Jim, it will certainly use less amps with 220v, about half. But Watts is the apples to apples comparison in this case, not amps. :)
View Elizabeth's profile
Elizabeth
817 posts in 3172 days
#11 posted 10-18-2011 09:37 PM
I converted mine, partly because I wanted to see if I could do it and mostly because by using the 200v plug in the ceiling I could avoid running a 110v extension cord across my shop. I wrote up a blog post about how to do it here:
http://lumberjocks.com/Elizabeth/blog/24647
View Bill White's profile
Bill White
4950 posts in 3989 days
#12 posted 10-18-2011 10:15 PM
I have a dedicated 240 v for the TS and the compressor. Other than a bit quicker on the start-up, I find no difference.
Bill
-- bill@magraphics.us
TopamaxSurvivor
#13 posted 10-18-2011 11:08 PM
What size are the motors Bill? I will bet, 1 hp or larger ;-)
