Steam bending
Forum topic by richgreer posted 10-16-2011 02:38 PM 4558 views 0 times favorited 15 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3044 days
10-16-2011 02:38 PM
Normally, when I think of steam bending (which I have never done) I think of a rigged up outdoor apparatus with a fire, boiler and a pipe that is used for steaming wood.
Then it occurred to me. We use a steamer on the kitchen stove to cook a few different foods. If I wanted to steam bend a small piece of wood, could I steam it in that same steamer?
I’d like to steam bend some thin strips of wood to make what would look like a curled ribbon.
Has anyone ever tried steaming wood in a kitchen steamer? Any advice (other than do it when my wife is away and clean up before she gets home)?
15 replies so far
View Howie's profile
Howie
2656 posts in 2892 days
#1 posted 10-16-2011 02:49 PM
Rich: I’ve done some bending but not on the stove. I’d try it. What can you be out but a few small pieces of wood.
I borrowed a wall paper steamer from (LJ)Camper and built a box and it worked pretty good. I have since found a Wagner wall paper steamer at Goodwill,almost brand new, for $20.00. When I found it, I was looking for a big tea kettle to use on the 5th burner of my gas grill. It really doesn’t take much.
-- Life is good.
View 489tad's profile
489tad
3353 posts in 2981 days
#2 posted 10-16-2011 03:14 PM
I thought about it. So I took our big pot and unscrewed the knob on the lid. A fitting could be attached to the lid. Fitting to hose, hose to steam box, steam box to drain in the sink. I think it would work.
-- Dan, Naperville IL, I.G.N.
View grizzman's profile
grizzman
7836 posts in 3273 days
#3 posted 10-16-2011 03:20 PM
hey there rich , good subject to bring up, yes what you are talking about would work very well, if you have a pan that has a tight enough lid to hold most of the steam , then it will work very well, i have a stainless stell pan that i bought originally for smoking foods, and it has a wire rack in it as well, something like this for you would work for what your asking about, you might look around in yard sales and the like and maybe find one your wife would not mind you using for wood work, would like to know how it worked for you, but i know it will work, make sure you steam the wood well, you know the larger the piece , thickness and the likes, you need longer steam time, just a few pointers….have fun…oh i wanted to ask how your wife’s father is doing, take care
-- GRIZZMAN ...[''''']
View Jim Bertelson's profile
Jim Bertelson
4170 posts in 3134 days
#4 posted 10-16-2011 05:50 PM
You own a pressure cooker Rich? How about one of the big canning pressure cookers? My mother used the pressure cooker for a lot of stuff. We were poor, and pressure cookers saved on gas or electricity, and the meal cooked faster.
Oh well. Don’t know a thing about this topic, but thought the pressure cooker approach might work.
-- Jim, Anchorage Alaska
View shipwright's profile
shipwright
7968 posts in 2767 days
#5 posted 10-16-2011 06:18 PM
Hi Rich
Maybe I can shed a little light here. I’ve done a lot of steam bending, all large to very large stuff but the bottom line is that the main reason we use steam is for convenience. It is simply not convenient to toss fourteen foot long boat ribs or larger planking in a pot of water. It is however easy to do so with small pieces so If I were doing it I would just toss them in boiling water like pasta and check occasionally until the pieces were “done”.
It’s also harder to “overcook” the wood in water.
View tenontim's profile
tenontim
2131 posts in 3714 days
#6 posted 10-16-2011 11:09 PM
I agree with shipwright. Also if you use green or non kiln dried wood, you’ll have better results.
View sras's profile
sras
4791 posts in 3099 days
#7 posted 10-17-2011 12:33 AM
I’ve done the boiling water thing before as well. I have even done longer pieces in the bathtub. I have had success with thicknesses less than 1/4”. Never tried anything thicker.
View bent's profile
bent
311 posts in 3638 days
#8 posted 10-17-2011 01:03 AM
it works on the stove, i’ve done it.
http://lumberjocks.com/projects/46536
View Jim Finn's profile
Jim Finn
2648 posts in 2891 days
#9 posted 10-17-2011 02:41 AM
No bending involved in this bow. Cut on a scroll saw. The bending I have done( Not this) I have done cold using 1/8” ply after soaking overnight in water.
-- Website is https://craftingcouple.com/
View BENTWOOD's profile
BENTWOOD
373 posts in 1751 days
#10 posted 10-27-2013 04:56 PM
I am only experienced with thin wood veneers I cut 1/32”-1/64” thick but stove, microwave and pressure cooker all work for veneers. Ultimately it depends on what size, type and thickness of wood being used. If very thin veneers and small quantity I would suggest you make some wood pasta with a stove pot. :)
Pressure cooker will work better for stubborn and/or thicker woods.
-- http://www.bentwoodjewelrydesigns.com
View lew's profile
lew
12019 posts in 3725 days
#11 posted 10-28-2013 12:24 AM
I’ve bent some thin pieces using one of those “expandable” steamer devices- they look like a space reflector from a James Bond movie and a large shallow “dutch oven” covered pot.
An inch or so water in the bottom put a lid on it. All my pieces were short enough to fit into the pan and lay on the steamer platform. Worked for what I needed.
View Moron's profile
Moron
5032 posts in 3863 days
#12 posted 10-28-2013 01:10 AM
many times
the application of thought to a desired result, if only ending in failure, can end in a very happy day
as weird as that sounds, its true
bending things, be it the rules or a piece of wood, is time well spent on things that matter.
Moron
#13 posted 10-28-2013 01:18 AM
funny
this thought always perplexed me
Moron
#14 posted 10-28-2013 01:21 AM
thoughts ?
Moron
#15 posted 10-28-2013 01:30 AM
u need a special person to make life work
boil them, steam them until they give up
then bend them at your leisure
