butcher block kitchen counter protection?
Forum topic by ocwoodworker posted 10-16-2011 06:20 AM 1295 views 0 times favorited 3 replies Add to Favorites Watch
View ocwoodworker's profile
ocwoodworker
209 posts in 2974 days
10-16-2011 06:20 AM
Just installed a butcher block counter. What is a good protection against moisture?
-- I'd like to believe Murphy's Law haunts my woodshop, because if it's Karma it would mean I had something to do with it. - K.R.
3 replies so far
View CharlesNeil's profile
CharlesNeil
2389 posts in 3840 days
#1 posted 10-17-2011 06:40 AM
for a hand applied finish. look to general finishes Arm R Seal, or water lox, for a sprayed finish look to general finishes Endurovar…
View Bill White's profile
Bill White
4910 posts in 3930 days
#2 posted 10-17-2011 08:15 PM
A good quality wiping urethane varnish will work well. I have used water based stuff with good results. Be prepared to apply several coats for max protection. Buff with a synthetic pad between coats for a slick surface. I will also wax after final coat. I don’t use a gloss finish. Satin will look good.
You didn’t state what wood was used. Help us help ya.
Bill
-- bill@magraphics.us
View dbray45's profile
dbray45
3320 posts in 2746 days
#3 posted 10-17-2011 08:19 PM
Also, are you going to cut on this counter? I have a cherry counter and used marine polyurithaene on it. Looks great after more than a year but we do not cut on it. If you use it as a cutting surface, the rules are different.
-- David in Damascus, MD
