outfeed miter slots
Forum topic by jpc posted 10-16-2011 05:40 AM 4289 views 0 times favorited 15 replies Add to Favorites Watch
View jpc's profile
139 posts in 3116 days
10-16-2011 05:40 AM
Topic tags/keywords: question tablesaw router
Good evening everyone, just had a question , and wanted to know what you guys did for yours. Im about to route in the grooves in my outfeed table. Did you guys route a little big , or exact size and shape of your miter gage runner bar? As i dont have a bit that would undercut to trap the runner under the edge, Am i overthinking this and missing something guys? any input is appreciated
15 replies so far
View Sawkerf's profile
1730 posts in 3003 days
#1 posted 10-16-2011 05:48 AM
My workbench doubles as my outfeed table, and I routed slots in the top that line up with the miter slots. Since all I wanted was clearance, the table slots are wider than the saw miter slots.
-- Adversity doesn't build reveals it.
View rep's profile
95 posts in 3044 days
#2 posted 10-16-2011 06:24 AM
Since the grooves are just clearance for the miter gauge bar (or other jig using the miter slots) – I used a router and straight edge to make grooves a little larger than the slots. No need to be exactly the same as the saw table slots. Once the work is past the blade, there is no need to keep guiding the bars precisely onto the out feed table.
-- rick
View Dusty56's profile
11819 posts in 3623 days
#3 posted 10-16-2011 06:39 AM
Is your table free standing or mounted permanently to the saw ?
Mine is free standing , so I made the slots 1” wide because the last thing you want is for the miter bar to stop moving if you’re part way through a cut.
As far as length goes , place your miter gauge just past your saw blade / riving knife / splitter , and see how far the runner extends over the table… don’t have to go much further because your stock will have been cut through by that time , and you will be clear of the blade. : )
View jpc's profile
#4 posted 10-16-2011 08:04 AM
Yes mine is mounted permanantly to the saw,the mounted section is only about 15-16 inches deep, so i planned to run it full length,and after pushing my miter gage past blade and splitter as you suggested the tip of the bar was about half way thru the table, so Im guess ill shoot for a perfect fit and not freak out if its a hair big, thanks everyone
16273 posts in 4153 days
#5 posted 10-16-2011 03:14 PM
I can’t think of any reason why a perfect fit would be an advantage. The miter slots on the saw table take you all the way through the cut. After that, the only thing you are concerned about is clearance.
And the downside of trying to make them perfect is that the slightest deviation (either too narrow or not perfectly straight) will create a problem.
13598 posts in 3276 days
#6 posted 10-16-2011 03:19 PM
i make them bigger
sawdust can clog the track
and drill a hole at the end
so the sawdust can drop thru
View gfadvm's profile
14940 posts in 2625 days
#7 posted 10-17-2011 04:47 AM
My outfeed table/workbench is 1/2” below the surface of my tablesaw so I don’t need to slot my bench. Just remember to raise your blade a little higher and the 1/2” step hasn’t been a problem. If I’m cutting really long stock I may lay a 1/2” scrap on the outfeed to keep things level.
View rance's profile
4255 posts in 3095 days
#8 posted 10-17-2011 05:52 AM
I like Andy’s solution of 1/2” lower.
4909 posts in 2428 days
#9 posted 10-17-2011 01:16 PM
I made mine wider.
View shipwright's profile
7939 posts in 2733 days
#10 posted 10-17-2011 03:05 PM
I have an outfeed table that is on casters and doubles as many other things so instead of slots that must be lined up I just have a piece of hardwood on the edge that faces the saw that has a bevel on it that will easily “pick up” any drooping ripping and let it run on the table. I keep the table about a foot away from the saw table. Never had a problem.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
View Chris 's profile
1879 posts in 3926 days
#11 posted 10-17-2011 03:36 PM
I really like David’s (Patron) idea using the hole at the end of the slot to allow for sawdust to clear out.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View vernonator's profile
75 posts in 2586 days
#12 posted 10-17-2011 03:50 PM
Very fortuitious topic – in the planning stages for an outfeed table myself. Plan on a 18” section attached to the saw with a long fold-down top for those really long cuts. I too like the idea of holes at the end of the mitre grooves for sawdust relief and plan on making my slots oversized. Any advice on attaching the table to the L-bracket on the table saw? Did you drill/bolt? Make a bracket? Any closeup pics would be beneficial.
Thanks all for all the great info (on this thread and all the others)
View jusfine's profile
2422 posts in 2861 days
#13 posted 10-17-2011 05:20 PM
My blog about the outfeed table I built is here and it may give you some ideas.
I did not rout slots in mine as my miter guage is seldom used, I have the Excalibur sliding table attached to the left of my saw.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View jpc's profile
#14 posted 10-17-2011 05:23 PM
hey Vernonator, the night before last i posted pics of mine , its in the post project section or just look at my profile if you like, it has one or two close pics of underneath, i bolted 1 1/2×1 1/2 angle vertically to the back of my saw and same size angle underneath the outfeed table and then used clamps to set the table to exactly where i wanted it, put the flat steel in place and marked where i need to put two holes in each one, then bolted it all togather, still gotta do some sanding and then finish, good luck
View flippedcracker's profile
91 posts in 2388 days
#15 posted 10-18-2011 01:04 AM
I’m getting a new saw soon, and will definitely be building an outfeed table, so i’m interested in these ideas too. And since my garage is so small, I also need to make the table extremely functional and full of storage so as not to waste any space.
