| Forum topic by gfadvm | posted 583 days ago | 867 views | 1 time favorited | 15 replies | ![]() |
583 days ago |
Topic tags/keywords: saw blade cleaning blade After all the positive comments here, I bought a gallon of this today. Now the question: do you use it straight, dilute 1:10 (light cleaning) or 1:1 (heavy cleaning). The light and heavy came from the label. Do you soak blades or just spray and brush? Thanks. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
15 replies so far
#1 posted 583 days ago |
I use it full strength. Soaking saves a little work, but spraying and brushing works too. -- Charlie M. "Woodworking - patience = firewood" |
#2 posted 583 days ago |
A tip that I picked up on this site that works great. Use the lid from a five gallon paint pail to soak your blades in. Just the right size for a ten inch blade and you don’t waste a lot of your cleaning product. -- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it. |
#3 posted 583 days ago |
I use a 12” pizza pan that I found in the shop attic. Perfect size. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#4 posted 583 days ago |
I use throw-away pizza pans, soak at full strength for 5 – 10 minutes, and scrub with an old toothbrush. -- Adversity doesn't build character...................it reveals it. |
#5 posted 582 days ago |
I dilute, which mostly means (I think) it jut has to soak a little longer. BTW, I also use for soaking drum sander belts, when they get some resin burned into them; at least I used to, before I quit sanding soft wood on my drum sander. One other thing it excels at is removing bugs from your car. Spray a little on the bugs, the bigger tougher ones might need a paper towel laid on them and then spray it to get it wet. 10 minutes later they wash right off. Then finally, I also use to spot treat our carpet when I’m cleaning it. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#6 posted 582 days ago |
I use a 5 pound hand sledge -- When the moderator chooses sides, his site sucks. |
#7 posted 582 days ago |
I use Extreme Simple Green, approved for airplane use, and dilute 50%. Just spray on, wait a few minutes and brush with a brass brush. -- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you. |
#8 posted 582 days ago |
Simple Green works well as does Arm & Hammer Washing Soda (not baking soda). -- bill@magraphics.us |
#9 posted 582 days ago |
Regular Simple Green full strength, soak for a max. of 5 minutes then use one of those bathtub cleaning brushes with a handle, the ones that look like a row boat. |
#10 posted 582 days ago |
Full strength is fine, but the maker of Simple Green suggests not soaking, as it can cause issues with the carbide. For soaking they recommend Simple Green Pro HD. If you’ve got the original Simple Green, just spray it on, brush the teeth, and rinse it off within a few minutes. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#11 posted 582 days ago |
Which “Simple Green” types do you all use? Stock codes might be nice. :) -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#12 posted 582 days ago |
50/50 solution, soak for a 5-10, then I use a nail cleaning brush to remove what hasn’t dissolved or floated off. -- Sawdust and shavings are therapeutic |
#13 posted 582 days ago |
Just to let you know,Freud recommends against Simple Green |
#14 posted 582 days ago |
I have used washing soda and goof off with good good results. I use a large metal movie real holder I got at a garage sale too soak my blades in. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#15 posted 582 days ago |
Knotscott: I knew I had read that somewhere.(about the carbide) -- Don't rollerskate in a buffalo herd |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
