Saw question
« back to Coffee Lounge forum
Forum topic by GMman posted 10-15-2011 09:37 PM 1286 views 0 times favorited 19 replies Add to Favorites Watch
View GMman's profile
GMman
3902 posts in 3567 days
10-15-2011 09:37 PM
Topic tags/keywords: question
Anyone ever used this saw and what is it called?
19 replies so far
View ShaneA's profile
ShaneA
6877 posts in 2468 days
#1 posted 10-15-2011 09:42 PM
Looks like a bosch cordless multitool.
View David Grimes's profile
David Grimes
2078 posts in 2509 days
#2 posted 10-15-2011 09:49 PM
Sure does. Multitools are great. I have the corded and battery models and they are used quite frequently.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View Jim Bertelson's profile
Jim Bertelson
4147 posts in 3034 days
#3 posted 10-15-2011 10:19 PM
I have the corded, and I use it on essentially every project. It pinch hits as a detail sander, although it isn’t random orbital. I just move it around a bit as I use it and it works find. I can make straighter cuts than with my jig saw, and I have used it to cut metal as well. The more you use it, the more uses you find. It is constantly plugged in under a bench in my shop.
-- Jim, Anchorage Alaska
View Jim Jakosh's profile
Jim Jakosh
19943 posts in 2975 days
#4 posted 10-16-2011 11:43 PM
That’s it and they are real handy!!
View Sawkerf's profile
Sawkerf
1730 posts in 2938 days
#5 posted 10-17-2011 01:26 AM
I have the Dremel corded version of that and wouldn’t be without it. My big use is to cut baseboards for cabinet installations. No more pulling a piece of base, cutting it down and re-installing. Now, i can cut off what goes away and I’m done.
GMman
#6 posted 10-17-2011 01:37 AM
Thanks all I will have to get me one
404 - Not Found
2544 posts in 2839 days
#7 posted 10-17-2011 02:32 AM
Yes it’s a cordless multitool. The saw is the only thing I use it for and its great for trimming skirting boards when you have to fit a unit up to the wall.
Jim Jakosh
#8 posted 10-18-2011 02:54 AM
Gman, they sell a cheaper knock off with a cord at Harbor Freight.It works good for anything I do with it. Being able to get into corners and right against a surface is a big plus.
GMman
#9 posted 10-18-2011 03:12 AM
Thanks Jim I will ckeck it out
GMman
#10 posted 10-22-2011 11:07 PM
Well I got me a corded multitool variable speed 10,000-18,500 opm today, 2.5Amps, 12 piece kit, case 3 year warranty for $39.99 on sale plus tax.
Did not try it yet monday I will give it a try.
View miles125's profile
miles125
2180 posts in 3875 days
#11 posted 10-23-2011 04:56 PM
Great for cutting off installed basemould, chairrail and crown mouldings.
-- "The way to make a small fortune in woodworking- start with a large one"
View jim C's profile
jim C
1472 posts in 2968 days
#12 posted 10-23-2011 04:56 PM
I have the Dremel version and after 5 minutes it gets too hot to handle. Anyone else have this problem?
View chrisstef's profile
chrisstef
17098 posts in 2876 days
#13 posted 10-23-2011 05:13 PM
im with ya on that Jim … mine gets smoking hot after about 1o minutes, but they come in handy once in a while.
jim C
#14 posted 10-23-2011 05:42 PM
Once in a while is key. I agree they’re handy, but if you used this in daily contracting, you’d have to have an asbestos glove. ;-)
View Dez's profile
Dez
1166 posts in 3947 days
#15 posted 10-24-2011 06:58 PM
I own the Dremel! I have not had any problems with it at all. I ran it almost constantly for about 30 min cutting down an over the fridge cabinet so that my neighbors could fit the new fridge in. I have also used it a bit for sanding too.
Contact Dremel and let them know about the problems you are having. I’d be interested to know what they do to resolve it!
-- Folly ever comes cloaked in opportunity!
