Dust Collector Accessories
Forum topic by seabiscuit posted 10-14-2011 01:33 AM 1684 views 0 times favorited 10 replies Add to Favorites Watch
View seabiscuit's profile
seabiscuit
95 posts in 2329 days
10-14-2011 01:33 AM
I am purchasing a new dust collector. From my understanding, it comes with almost nothing (except some bags).
This is the Harbor Freight 2 HP one and I plan on getting a 1 micron bag from amazon for $35 or so.
What else should I get? Is there a good starter kit that has some hoses and such? What is needed? I plan on only using it on one tool at a time and moving the hose from tool to tool.
I have a band saw with a dust collector port and a router with a port.
I also have a table saw with no port, a miter saw with no port.
What would I need to get up and running?
Thanks
10 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2538 days
#1 posted 10-14-2011 02:12 AM
I’ve found the linked reducer/connector to be handy. Most of my machines have a 2.25/2.50” dust port. Of course, my DC has a 4” hose, so this accessory is a must…..especially at the $3.99 price.
I had to wrap some duct tape around the connector nozzle so it would fit a couple machines with 2.5” ports.
http://www.harborfreight.com/garage-shop/machinery-accessories/4-inch-x-2-1-4-quarter-inch-hose-connector-96457.html
View richgreer's profile
richgreer
4541 posts in 2980 days
#2 posted 10-14-2011 02:33 AM
I’m a big fan of Rockler’s Dust Right system. The link below takes you to the starter system. You’ll probably need to add to that. I have a port on each of 7 different machines and it is relatively easy to move the flexible and expandable hose from one to the other.
As an FYI, I did some custom work so the port at the back of my TS connects to a hose that connects to a port that is in front of the TS. I did the same thing to connect to my miter saw. The result is 7 ports that are relatively close together and it is easy to move from one to the other.
Also – I don’t know much about your DC, but if it is a single stage (common) you will really want a cyclone separator to catch the heavier particles before the hit the whirling blades.
http://www.rockler.com/product.cfm?page=20375&filter=dust%20right
richgreer
#3 posted 10-14-2011 02:36 AM
One more – - I really like having a remote control to turn my DC on and off. It may sound like a frivolous idea, but it sure is handy. I always keep my remote control in my pocket and I can turn the DC on and off very conveniently.
View Don W's profile
Don W
18605 posts in 2473 days
#4 posted 10-14-2011 03:08 AM
i know both woodcraft and grizzly has starter kits for dust collectors. I’m sure other retailers have the same.
seabiscuit
#5 posted 10-15-2011 03:59 PM
Anyone tried the harbor freight accessory pack. $40 and comes with 2 hoses, 2 blast gates, a bunch of clamps, and some other stuff….
Also…still haven’t heard any ideas for table saw dust collection.
Thanks
seabiscuit
#6 posted 10-15-2011 04:01 PM
@ richgreer
I can’t really visualize your custom table saw setup
View TechRedneck's profile
TechRedneck
767 posts in 2762 days
#7 posted 10-15-2011 06:17 PM
Rich has some good advice. Get a separator, I use one that fits on a steel 35 gal trash can. Well worth it. There are pics on my shop page.
If you are not hard piping then a quick disconnect works good. Woodcraft or Rockler have squeeze clamps. I would also get the good clear hose if you are moving from tool to tool. The remote start is WELL worth the money. Watch for a sale.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View rum's profile
rum
148 posts in 2491 days
#8 posted 10-16-2011 07:47 AM
Build a base under the TS to add a dust port, its definitely a huge improvement. If you look around there are lots of builds for that.
For the separator build a Thien baffle, they just work (better than most of the commercial offerings in this class) http://www.cgallery.com/smf/index.php?board=1.0
Go with the biggest hoses you can to the tool (note that the HF is really limited to 5” or maybe 6”, but 6” seems to be pushing it). I run 5” out of my baffle and its just barely enough for some tools (I’d actually like a few more cfm.. but not complaining for what I have invested).
For the filter if you can swing it price wise get the Wynn 35A, this is a hepa and actually improves the airflow a fair bit because of the greater surface area (the guys at wynn environmental are great to deal with as well)
View crank49's profile
crank49
4029 posts in 2876 days
#9 posted 11-04-2011 12:50 AM
I know I’m late to the discussion, but I just now found it.
I bought the HF acessory kit when I bought my HF collector. It’s not bad. Had several extra parts I didn’t need, like an adapter to connect the hose to the bottom of a contractor saw, but pack rat that I am, I’m sure they will come in handy some day.
seabiscuit
#10 posted 11-04-2011 10:34 PM
@ Crank49
That is what I ended up doing. Works well for what I’m doing. Mounted the table saw “hood” under my table saw with some Velcro. Gets about 90% of the dust. Using the blast gates too and both hoses. Seems like a good deal considering it was the same price as one hose on amazon.
