Making your own pellets for heating the shop.
Forum topic by Allanwoodworks posted 10-12-2011 08:24 PM 2411 views 0 times favorited 8 replies Add to Favorites Watch
View Allanwoodworks's profile
Allanwoodworks
112 posts in 3014 days
10-12-2011 08:24 PM
Topic tags/keywords: pellet wood stove heat
Has anyone ever look into making your own pellets for a pellet stove? I just create so much sawdust milling wood and in the shop it’s a shame that it just goes to waist. My shop is heated by a wood stove but would like to convert to a pellet stove if it would be cost efficient. If anyone has any info or ideas about this let me know.
Ty
-- Ty, Up in Washington
8 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3241 days
#1 posted 10-12-2011 09:27 PM
You could probably make your own pellets if you could buy the equipment and supplies needed. I suspect, however, that your cost per pu would be several times whatever you would pay a retailer.
A local recycler might take the sawdust off of your hands.
View SASmith               's profile
SASmith
1850 posts in 3160 days
#2 posted 10-13-2011 01:15 AM
http://www.pelletpros.com/id68.html
I have seen them for about 1/2 the price of the ones offered in the link.
The cheaper ones I have seen in “Farm Show” magazine.
-- Scott Smith, Southern Illinois
View Brett's profile
Brett
950 posts in 2932 days
#3 posted 10-16-2011 03:20 AM
Ty, I think that this idea came from WOOD magazine but I have heard that one could pack the 1/2 gal. cardboard milk cartons with chips and sawdust and burn those. They need to be packed as tight as you can get them. I did it with some chips from the planer/jointer and it worked well but I wasn’t trying to heat with them just experimenting.
-- Hand Crafted by Brett Peterson John 3:16 http://www.TheCrookedNail.blogspot.com
View Al Killian's profile
Al Killian
85 posts in 2798 days
#4 posted 10-17-2011 03:49 AM
When my shop was in NY we would get the stove hot and then shovel in the shavings and chips. They burn hot and will heat up the shop quickly. I know they have kits to make your own firelogs that you can burn int the regular wood stove. This might be a better option.
-- Owner of custom millwork shop
View Paul liddy's profile
Paul liddy
5 posts in 2586 days
#5 posted 10-17-2011 08:03 PM
In order to make wood pellets it takes very high pressures to pack it enough to work. There is nothing added to the saw dust to hold it together, I burn apx. 4 tons a year, that is a lot of sawdust.
-- pau
View dmmflys's profile
dmmflys
43 posts in 2570 days
#6 posted 11-04-2011 12:41 AM
Check this out it might be an idea for you to save a few $$ if you have the time to commit to it and access to lots of news paper. I never personally used it by people have told me they work ok. http://www.amazon.com/UniFlame-C-4301-Uniflame-Newspaper-Roller/dp/B0012M9UZ6/ref=sr_1_1?s=furniture&ie=UTF8&qid=1320342383&sr=1-1
I’m currently doing research on using sawdust from home shops like ours to make “Sawdust logs” that you could burn in a fire place or pot belly stove. Stay tuned I’ll post more info as I get it.
Dave
View Howie's profile
Howie
2656 posts in 3096 days
#7 posted 11-04-2011 12:52 AM
Just be careful and remember…sawdust will flash/explode.
-- Life is good.
View jimferguson's profile
jimferguson
1 post in 2504 days
#8 posted 01-07-2012 09:58 AM
I always use a gas heater to heat my shop. I didn’t use the pellets ever.I think heater is also a very easy & effective way to heat a shop. I think you should also go for it. But i want to know about the pellets.
heating and cooling Olathe | heating and cooling Olathe
