Tips & Tricks: Tearout
Forum topic by MsDebbieP posted 10-12-2011 02:22 PM 1590 views 0 times favorited 7 replies Add to Favorites Watch
18615 posts in 4157 days
10-12-2011 02:22 PM
Topic tags/keywords: tearout tips tricks
what are your tips/tricks/strategies re: tearout
prevention? fixes?
(also add links to helpful blogs etc that are related to the topic)
Gateway to all Tips & Tricks Topics
7 replies so far
View Gene Howe's profile
Gene Howe
10479 posts in 3425 days
#1 posted 10-12-2011 03:32 PM
In solid wood, always cut or rout the cross grain first.
Sometimes, a knife cut along the saw cut line will reduce tear out. Especially in plywood.
Painters tape helps, too.
Accurate fence to blade alignment is a must with plywood.
Use SHARP tools.
View longgone's profile
longgone
5688 posts in 3305 days
#2 posted 10-12-2011 03:38 PM
backer boards whenever possible work for me.
View Bill White's profile
Bill White
4929 posts in 3957 days
#3 posted 10-12-2011 03:54 PM
High ATB blades on the TS and a zero clearance insert in addition to the above mentioned tips.
Bill
-- bill@magraphics.us
Gene Howe
#4 posted 10-13-2011 02:44 PM
One more tip for solid wood.
Dampening the area to be milled often helps.
View Murdock's profile
Murdock
128 posts in 2480 days
#5 posted 10-13-2011 09:44 PM
On plywood, you can make 2 cuts, one just deep enough to cut through the face veneer then the 2nd to the full depth.
Also when using tape on your cut, remember to pull the tape off toward the cut edge, if you pull it the other way you can pull up bits of the wood that were left a little loose during the cut pretty much negating the benefit of the tape. Doesn’t happen all the time, but often enough that I remember now.
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
View Dan's profile
Dan
3630 posts in 2877 days
#6 posted 10-13-2011 09:58 PM
When I get tear out from the power machines I always fix it and clean it up with my hand planes. When the grain is going in different directions its hard to avoid tear out when going through the planer. With a good sharp hand plane you can work with the grain to clean it up….
For ripping on the TS I also have used tape as murdock suggested… works great especially when cutting dados.
-- Dan - "Collector of Hand Planes"
View tom427cid's profile
tom427cid
294 posts in 2467 days
#7 posted 10-14-2011 07:38 AM
The worst tearout/splinters that I have encountered has been in Purpleheart 1/2” rounds that have been finished. I finally figured how to eliminate almost all of the issue. First I use a sawblade with negative hook.It’s 4 degrees. The second thing that I have learned to do is to orient the growth rings about 45 degrees to the cut. This has eliminated about 90% of the problem.
Hope this helps.
tom
-- "certified sawdust maker"
