| Forum topic by soccer2010 | posted 591 days ago | 816 views | 0 times favorited | 3 replies | ![]() |
591 days ago |
Topic tags/keywords: jig incra joint joinery joining I found an Incra Ultra Pro (25”) for $125. I have the Incra Miter gage and I like that a lot. I’m looking to make boxes. Thoughts on the Ultra Pro?? -- John, Ohio |
3 replies so far
#1 posted 586 days ago |
John, Hard to say exactly what you have there. If it’s an Ultra Lite with an upgraded fence- it’s probably an okay deal. If it’s a 25inchLS system with a Wonder Fence/Ultra upgrade it is a very good deal. -Jack |
#2 posted 586 days ago |
John, I had an Ultra Pro, and recently was able to trade up to an LS. The LS is smoother to use (my opinion), the Ultra would hang up and I had to fiddle with the release lever to get the jig to slide. There is no dust collection behind the fence, unless you add the Wonder Fence, which might require you to buy and replace the existing fence before upgrading. I think it depends on the age of the jig. You can find details about this on Incremental.com. The Ultra uses the “original” toothed rack system for the increments and the LS uses the lead screw. I believe this feature make the LS jig run smoother. Functionally, the Ultra is capable of making every joint or cut that the LS can, and for $125, it’s not a bad buy. The question is in the upgrades….....Also, with the 25” jig, you could easily adapt this to your table saw using a simple sliding plywood jig…... Good luck. Jeff -- Jeff - I have not failed. I've just found 10,000 ways that won't work. |
#3 posted 586 days ago |
Thanks for the feedback. I think I’ll wait for an LS model. I’m also looking for an inexpensive ring master. -- John, Ohio |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3555 |
15813 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
