Finishing White Pine Carving
Forum topic by SeaboltWoodDesigns posted 10-11-2011 11:08 PM 2189 views 0 times favorited 3 replies Add to Favorites Watch
View SeaboltWoodDesigns's profile
1 post in 2354 days
10-11-2011 11:08 PM
Topic tags/keywords: question pine carving tool carving finishing arts and crafts
I decided to try my hand at power carving with my dremel. I’ve never done any carving of any sort before. This is my first project and I have no idea how to “finish” it. I’m wanting to stain it. It’s a gift for a good friend of mine that I do cancer awareness event’s with. How do you guys suggest that I finish it? Thank you!
-- Joshua Seabolt Wood Designs
3 replies so far
View wisno's profile
88 posts in 2942 days
#1 posted 10-19-2011 08:42 AM
It is nice stuff. You can enhance your carving with the gaze application.
The glaze will fill in and coloring inside your carving and make more life looked.
your finishing step should be as follow:
1. Sealer let it dry, sanding
2. Glaze application, highlight
3. Sealer
4. Top coat.
Finishing for the carved wood
Good luck
View Earlextech's profile
1160 posts in 2622 days
#2 posted 10-19-2011 04:00 PM
I like the idea of glazing this project, it will make it stand out better.
I would seal with sealcoat, sand to 320, don’t skip grits, then I would use a latex paint in the color you want to do the glazing. Latex is inexpensive, color can be created easily and thinned to be made more transparent. Decide how much coverage you want, then thin accordingly, flood the surface with material then wipe off the excess. It’s important to wipe with vigor, don’t let it absorb more in one area than another. You should be trying to completly remove it from the top surfaces and leaving the most at the bottom surfaces. Let dry, then top coat with a couple coats of sealcoat.
It will be beautiful!
View Rustic's profile
3253 posts in 3527 days
#3 posted 10-19-2011 04:18 PM
Nice carving on your first try. you are a natural
--, Rick Kruse, Grand Rapids, MI
