Rousseau router plate question
Forum topic by joshtank posted 10-11-2011 03:26 PM 2972 views 1 time favorited 5 replies Add to Favorites Watch
View joshtank's profile
joshtank
224 posts in 2974 days
10-11-2011 03:26 PM
Topic tags/keywords: table saw router table triton router
So I got the 2 1/4 triton and the rousseau plate, and installed them in my table saw extension. heading to the store today for a 20 amp switch and the necessaries to make sure sure i don’t have to go under the table to switch it on.
i know the rousseau plate has a slight grade to it.. it rises up a bit in the middle. does anyone have this plate, and have you used mated bit sets with it? your results?
thanks.
-- Josh - Jacksonville, FL - https://www.youtube.com/channel/UC6eXmOxkM10zI0d-njOHeRQ
5 replies so far
Rick Dennington
5864 posts in 3195 days
#1 posted 10-11-2011 05:00 PM
Josh,
I’ve used the Rousseau plate in two other r.ts. I’ve built, and never had a problem with either one. In fact, I’ve still got a brand new one in the package, unopened. The last r.t I built was the NYW by Norm, and I used a Rockler metal plate in that one. But…the Rousseau will hold up to anything you throw at it. I had (have ) a Hitachi M12V mounted to mine, and no problems. I like it for the fact you can remove the inserts easily, and go up to panel raising bits, if needed. For my $$$$, the Rousseau is a good insert…just not as strong as the metal ones, but will serve you well.
View Howie's profile
Howie
2656 posts in 2924 days
#2 posted 10-12-2011 04:01 AM
I’ve had mine for over 5 years with a R1100 hanging on it and no problems.
-- Life is good.
View superstretch's profile
superstretch
1531 posts in 2694 days
#3 posted 10-18-2011 08:45 PM
Is that.. an old Craftsman TS?
-- Dan, Rochester, NY
joshtank
#4 posted 10-18-2011 08:54 PM
yep yep. nothing fancy but it’s working out nicely!
superstretch
#5 posted 10-18-2011 08:55 PM
Very interested in your convert to delta rails and fence.. The originals still work on mine, but I’d love a Bayes fence and plan on taking off a wing (or adding onto it) for a router table
