| Forum topic by Jimboe | posted 586 days ago | 510 views | 0 times favorited | 2 replies | ![]() |
586 days ago |
I have a box im making that has ebony accents . I was finishing it with poly and noticed that the maple was dry to the touch but the ebony wasnt …will poly cure on top of ebony ..and if not what do i do to make it work ?? |
2 replies so far
#1 posted 586 days ago |
Jim, Poly should do fine over Ebony. I have only worked with ebony once as an accent in a jewelry box and I put poly on it. it has such a tight grain that it doesn’t really “soak” it up…which is fine. Poly is a film finish and doesn’t need to soak in. The only thing I can think of when applying to ebony and maple in the same project is that the film on the ebony may build quicker than on the maple. Will this cause an uneven finish at the transition from maple to ebony? I don’t know but I could see how that may occur. I would say make sure you sand well in between coats and that may help alleviate that…if it does start to happen. Hope that helps some. Good luck. Greg -- "Hey, you dang woodchucks! Quit chuckin' my wood!" |
#2 posted 585 days ago |
thanks Greg i was worried it might not cure …the box you made is beautiful love the way you did the accents!!! Thanks again my friend . |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
