Elk Horn and Walnut slab table
Forum topic by bloney posted 10-10-2011 10:01 PM 1293 views 0 times favorited 3 replies Add to Favorites Watch
View bloney's profile
bloney
2 posts in 2324 days
10-10-2011 10:01 PM
Topic tags/keywords: walnut
Greetings. I am new to the forum and am need of some insight to a project I am going to be working on. I have recently acquired two very nice Black walnu crothwood slabs. They are roughly six feet long and run 18” wide up to 24” at the crotch end. They are 2 3/4”thick. My desire is to construct a coffee table using the slab as the top and Elk antlers as the base/legs etc. I need some advice regarding the attachment, and construction of the elk horn base. I am having to purchase the horns so can’t really make any mistakes while constructiong table. Your help is appreciated.
3 replies so far
View gagewestern's profile
gagewestern
308 posts in 3254 days
#1 posted 10-10-2011 10:48 PM
i start with supporting the top at the hight i want . then adjust the antler to suit me mark the contac point and direction the screw must go. i use finish head screws as often as i can . other screws are ok as long you can counter sink them . to hold antlers together ( to each other while building) i use zip ties. mix dif colors of elmers putty together to get the color that matches the antler.
-- gagewestern
bloney
#2 posted 10-12-2011 11:51 PM
How many antlers and how long for a coffe table that is 60” long and ranges from 18” to 22” wide?
Thanks
View CaptainSkully's profile
CaptainSkully
1565 posts in 3462 days
#3 posted 10-13-2011 04:08 PM
This topic would also work in the design forum.
-- You can't control the wind, but you can trim your sails
