3/8 - 16 dowels
Forum topic by vejesse posted 10-10-2011 07:35 PM 2060 views 0 times favorited 5 replies Add to Favorites Watch
View vejesse's profile
vejesse
1 post in 2470 days
10-10-2011 07:35 PM
Hi guys, I’m new to the forum. I work as a luthier in Wisconsin and I’m looking to produce a small wooden part that incorporates a small threaded wooden spindle..
I was searching the internet for what I’m looking for and ran into a related thread on Lumberjocks. Someone with the handle TedS. mentioned he had found a supplier of wooden dowels threaded 3/8 -16. I was going to give him a message directly but I guess I can’t do that yet so I figured I would post something here.
I realize 3/8 – 16 is pretty small for wooden threads but I’m looking for a supplier in the U.S. that can produce this size thread in dowels made of a tough wood such as boxwood. Ebony would be even better. The length of the final part would be 1 1/2”, but I could use a longer dowel and cut lengths. The O.D. of the dowel before threading would be 0.370” (0.005” less than a full 3/8”) for less binding up.
I guy I used to work for had some luck doing this with a metal lathe. He would attach a Dremel tool to the tool post, chuck a small 60 degree cutter in the Dremel and feed it with the lead screw of the lathe. The dowels were boxwood first turned on a wood lathe and about 6 inches long. I guess the results were ok but it’s slow going and I want some parts in larger number and I don’t have the patience to mess with this. No problem tapping boxwood as it seems very tough but outside threads are a different story.
The Josef Teller company in Germany makes a part similar to what I’m interested in. The threads are M10 – 1.5, cut in ebony and the machined threads are very clean. I believe they use diamond or CBN tooling. I actually emailed them about making a version in 3/8 – 16 but they declined.
So, any ideas out there? I talked to about a half dozen specialty shops and nobody had a clue.
5 replies so far
View crank49's profile
crank49
4032 posts in 3020 days
#1 posted 10-10-2011 08:28 PM
Since 3/8-16 is the standard coarse thread for steel, why not just get a tap and die set for cutting steel threads and thread a piece of dowel
Does it have to be wood?
McMaster Carr has threaded rod in nylon, brass, bronze, aluminum, titanium, and of course half a dozed grades of steel.
View John Ormsby's profile
John Ormsby
1288 posts in 3786 days
#2 posted 10-10-2011 08:44 PM
Here is the link to TedS search for threaded dowels. It seems like he found a source but never posted it.
You might try emailing him.
http://lumberjocks.com/topics/11255
-- Oldworld, Fair Oaks, Ca
John Ormsby
#3 posted 10-10-2011 08:51 PM
You might have good luck with a metal lathe with threading capabilities. This way the dowel blank would be able to be milled rather than being subjected to the twisting force of a die.
View WayneC's profile
WayneC
13754 posts in 4147 days
#4 posted 10-10-2011 11:41 PM
Related to sending him a PM. You need to have 5 forum posts. Post a bit more and then you will be able to send him a message. This was done to keep the level of spam down on the site.
View sparks44pay's profile
sparks44pay
24 posts in 2583 days
#5 posted 10-11-2011 04:19 AM
There is a company called Chicago dowel that I believe sells threaded dowels. I don’t know if they have the size you want though. I use a Beall wood threader to make threaded dowels with my router. Here’s a link http://www.bealltool.com/products/threading/threader.php. I don’t think they have a setup to do a bolt that small or with that fine of thread though.
