Router guide bushing depth
Forum topic by Praki posted 10-09-2011 11:30 PM 1424 views 0 times favorited 2 replies Add to Favorites Watch
View Praki's profile
Praki
199 posts in 3991 days
10-09-2011 11:30 PM
Topic tags/keywords: router bushings guide collar
I have made a template for routing a pattern with 1/2 inch ply. However, I have a problem with the router bushing being much longer at nearly 3/4 inch. The bushing is 3/4 in OD and I see that as the OD goes up, so does the bushing depth. My first instinct was to grind the collar down to 1/2 in. The fact that wider bushings are also deeper seems by design and I am wondering if there is any downside to reducing the bushing depth. The alternative is to make my template with a thicker ply and have bits with enough cutting length.
So, do you think it is okay to shorten the bushings or am I asking for trouble?
-- Praki, Aspiring Woodworker
2 replies so far
View Gene Howe's profile
Gene Howe
10479 posts in 3423 days
#1 posted 10-09-2011 11:34 PM
It’s done frequently for just your reasons.
You won’t find any problems in doing it.
Praki
#2 posted 10-10-2011 01:36 AM
Gene – thanks for reassuring me. I went ahead and hacked the tip off and filed it smooth.
