Is Danish enough moisture protection for coasters?
Forum topic by ghazard posted 10-09-2011 04:05 PM 3091 views 0 times favorited 6 replies Add to Favorites Watch
View ghazard's profile
ghazard
382 posts in 3504 days
10-09-2011 04:05 PM
Topic tags/keywords: danish coasters moisture
Need to spit out a quick set of coasters and would love to just use a few coats of danish instead of poly. Enough moisture protection?
Thanks,
Greg
-- "Hey, you dang woodchucks! Quit chuckin' my wood!"
View tenontim's profile
tenontim
2131 posts in 3738 days
#1 posted 10-13-2011 05:07 PM
No, there’s not enough varnish in danish oil to protect the finish. Personally, I would finish them with several coats of pure tung oil. This finish will have to be renewed occasionally, but you won’t have the pealing top coat to deal with. Another option would be the thick bar top finishes that are on the market.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4122 days
#2 posted 10-13-2011 07:05 PM
Note: The term “Danish Oil” is generic and vague.
No two “Danish Oil” products are alike.
Some contain varnish and some don’t. While others may contain natural resins.
The oils used can vary from modified soya oil, linseed oil, tung oil and others.
One so-called “Danish Oil” is 100% Polymerized Linseed Oil, with no other additives.
An example of this vagueness is that one popular brand of “Danish Oil” is often said by “Internet Echoers” to contain a mixture of linseed oil, polyurethane and solvent. The manufacturer says that it contains modified soya oil, resin, colorants and solvent.
-- 温故知新
ghazard
#3 posted 10-14-2011 03:00 PM
It is deft danish oil.
Tim, what is the “pealing top coat” referencing?
Thanks!
Greg
hObOmOnk
#4 posted 10-14-2011 03:25 PM
Deftoil® Danish Oil Finish is one of the toughest “Danish Oil” products. It contains a mixture of tung oil, linseed oil and modified urethane resins. Properly apply at least three coats of this product and you should have a good finish.
-- 温故知新
tenontim
#5 posted 10-14-2011 03:45 PM
If the moisture gets under the “varnish” of the Danish oil, it will cause it to start flaking off. With pure oil, you won’t have this problem, but the finish will have to be renewed occasionally. If the coasters are for hot drinks, you shouldn’t have to worry about the Deft oil. Down here in Texas, coasters usually have iced tea glasses sitting on them.
ghazard
#6 posted 10-14-2011 04:11 PM
Thanks fellas. I appreciate the insight…
Greg
