Uploading photos for posts
« back to LumberJocks.com Site Feedback forum
Forum topic by twoblacklabs posted 618 days ago 421 views 0 times favorited 6 replies Add to Favorites Watch
View twoblacklabs's profile
twoblacklabs
120 posts in 888 days
618 days ago
Topic tags/keywords: trick photobucket
Just an informational item.
If I take a photo on my iphone, upload it to dropbox and then embed the image onto a post, via dropbox, the image is rotated 90 degrees and cropped.
Example 1:
However, if I take the same photo on my iphone, upload it to photobucket then embed the image onto a post via photobucket, the image is cropped but not rotated.
Example 2:
Custom doors
-- If You Haven't Got the Time to Do It Right, When Will You Find the Time to Do It Over?
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6328 posts in 1631 days
#1 posted 618 days ago
You might want to take a look at what resolution is, if you can set to a lower resolution it may help.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
twoblacklabs
#2 posted 618 days ago
Thanks.
Roger Clark aka Rex
#3 posted 618 days ago
800×600 looks good on LJs
View Joe Lyddon's profile
Joe Lyddon
6474 posts in 2249 days
#4 posted 618 days ago
Are you holding your iPhone sideways to get more of the door into the picture?
If so, you are taking it sideways… and you will be seeing the pic sideways…
If you want to change it, Rotate it 90 degrees Right, and Save it.. Most photo editing programs can Rotate pics.
twoblacklabs
#5 posted 618 days ago
Roger, I appreciate it. will try that.
Sorry Joe, that would be too simple. The issue is that the pics look fine on the local computer. It’s not until they are uploaded from my Dropbox folder to LJ site that the rotation occurs. Dropbox is used as a means to get the pic from iphone to computer and in this case, the LJ site. It is faster than syncing with the laptop. But it does not matter what method I use to get the pics to the laptop.
What I found is that if I don’t use Dropbox OR upload directly from my computer, but use photobucket instead, it works fine.
Joe Lyddon
#6 posted 618 days ago
OK… I figured THAT was going to be too easy… But, had to try… LOL
I have had people ask why their xxxxx tool doesn’t work… only to find it was not plugged-in… LOL
Sounds like you’ve discover a way to get the job done with GOOD results… GOOD!
I always, for the most part, upload to this site and it works pretty good…
Glad you got it!
