Finishing
Forum topic by GMman posted 131 days ago 196 views 1 time favorited 8 replies Add to Favorites
View GMman's profile
GMman
254 posts in 140 days
131 days ago
I have learned from a woodturner that the best finish you can have is using Minwax Tung Oil , the secret is lots of very vey fine sanding and if you happen to get a small scratch doesnot mater how long after the finish is on you can use the same Tung Oil and the scratch is gone
-- - - Tools are nice to have but you need someone to work them - -
View pappyjohn's profile
pappyjohn
138 posts in 156 days
131 days ago
GMman, thanks for the tip, question though can you put the tung oil over the top of other minwax stains. Say the new Red Chestnut from minwax.
-- Your Brother in WoodWorking John, Pittsburgh , PA.
8494 posts in 265 days
131 days ago
Thanks for the tip GMman. I have used tung oil for a number of my projects and it is easy to repair.
Pappyjohn you can use tung oil over Minwax stains. I have put it on several projects as a top coat after staining.
View David's profile
David
79 posts in 158 days
128 days ago
I use a lot of Minwax product for my finishes and continue to be happy with them. If the wood is porus; put some tung oil on the surface and sand with very fine grit paper, the dust will mix with the oil and fill the pores. Some guys call this “mulching” Yes; it is easy to repair compared to a thick varnish or poly.
Minwax stain accepts tung oil, varnish, poly and even oil paint (don’t know why one would) but I’ve never had a problem with it. On the other hand lacquer ~ I can’t print my thoughts on it; have no use for it, water spots, doesn’t agree with other finishes, scratches easily, difficult to repair, drys too fast and stinks ( literally).
View jjohn's profile
jjohn
393 posts in 156 days
128 days ago
Thanks. Got a lot to learn about finishing. Thanks for the tip.
-- JJohn
View tenontim's profile
tenontim
828 posts in 187 days
128 days ago
Hate to tell you this, but Minwax Tung Oil finish is not a pure tung oil product. Here’s the MSDS on it
http://hpd.nlm.nih.gov/cgi-bin/household/brands?tbl=brands&id=13018141. Most of the products with the word “finish” in the name are not “pure”. If you open a can of any of these and it smells like naptha, mineral spirits, or any other flammable liquid, it’s not pure and may just be varnish, with a little tung oil mixed in.
-- Tim -- http://tmuli.com
GMman
88 days ago
Tim ...Thanks for the tip did not know that
4804 posts in 294 days
88 days ago
Some tung oil products like ‘organ oil’ are good for wood turned finishes because it is food safe. although I would not take for granted that all tung oil products are food safe.
View Joey's profile
Joey
182 posts in 258 days
88 days ago
Grumpy is right, minwax “tung” oil is not tung oil at all, it has commercial dryers and fillers in it. Pure tung oil takes along time to dry and takes several coats to start building. My way around it is to mix equal parts of pure raw tung oil, boiled linseed oil and gloss poly. the poly and blo have dryers in them, so it helps the tung oil to dry. you get the warmth of tung oil and better speed and better build. If you build enought coats you can rub it out. I usually build 5 them rub it out with wax. You don’t get a plastic look, but you get protection for the wood.
-- Joey, Magee, Ms http://woodnwaresms.com
Bookmark And Share This Page
