What hole size to use and edge distance?
Forum topic by MrRon posted 10-08-2011 10:03 PM 964 views 0 times favorited 1 reply Add to Favorites Watch
View MrRon's profile
MrRon
5136 posts in 3416 days
10-08-2011 10:03 PM
I’m building a CNC router machine and using cross dowel nuts to secure parts together. They will be going into 3/4” MDO plywood. What is the recommended edge distance for cross dowel nuts? The nuts are 10mm dia, but measure .408” which is larger than a 13/32” drill. Should I go to the next larger size bit (27/64”) or even 7/16”?
1 reply so far
MrRon
#1 posted 10-09-2011 11:59 PM
Thanks, but what about the edge distance. I’ve set upon 5/8” edge to center of hole. Does this distance give enough “meat” for the screw to pull against?
