Keeping Glues and Stains from freezing in the winter.
Forum topic by woodjunkie posted 590 days ago 655 views 0 times favorited 6 replies Add to Favorites Watch
View woodjunkie's profile
woodjunkie
31 posts in 835 days
590 days ago
Topic tags/keywords: question heating shops
In a related post on keeping shops warm in winter there was some mention of how to keep glues and stains from freezing. I would like to hear more ideas on this. I live in Central Illinois and I heat my 16×26 shop with propane only when I am in it. Takes 30 minutes to go from 30 to 50 degrees. It is well insulated and unless it gets real cold rarely goes below 30 in the shop. But when it does anyone have any tricks on keeping glues and finishing products from freezing besides leaving the heat on all the time.
-- He: Can I get the plans for that? Me: Plans???
View Murdock's profile
Murdock
100 posts in 650 days
#1 posted 590 days ago
There is of course moving them into the house.
I have heard of people using an insulated box with a light bulb that is left on all the time inside.
I have seen a variation on that with a thermostat to keep it from getting to hot
Currently I move them into the house, but I am reorganizing my shop right now and seriously considering the light bulb method. My only concern is it just ‘feels’ like a fire hazard. I guess a thermostat would help with that some by preventing the temp from getting to high, but flammable liquids and hot bulb… just seems wrong.
Last year I did a test with a borrowed heater in the difference between keeping the shop at around 45 all the time compared to letting the shop cool off completely. The results were far from perfect, but it seems that once all the ‘stuff’ in the space is warm, it only cost a little bit more to maintain the temperature above freezing. Also made warming the shop up to ‘working temp’ much faster.
Would love to hear some more ideas from others as well
I may someday add heat to the shop, then my plan will be to thermostat control it and keep it above freezing all the time, but I do have pretty good insulation in my space to begin with.
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
Murdock
#2 posted 590 days ago
You got me thinking…
I wonder if something along the lines of a ‘pet’ heater would work in an enclosed space.
Something like this:
http://www.amazon.com/Heated-Resting-Small-Animals-Inches/dp/B000NVC7DO
Or this (more expensive and much bigger, but has a built in thermostat):
http://www.buy.com/retail/product.asp?sku=216914590&sellerid=25209263
The pad itself wouldn’t get hot enough to cause a fire hazard, but in an enclosed space may be enough to do the job.
ok, now you’ve done it, not going to sleep tonight while I research other possibilities. :)
View Cliff De Witt 's profile
Cliff De Witt
125 posts in 859 days
#3 posted 590 days ago
I use a heating pad in a Coleman cooler far from ideal but I live in Texas and we rarely have temps that low and when we do the temp of the contents keeps it warm unless I have to get a lot of stuff out.
-- Trying to find an answer to my son’s question: “…and forming organic cellulose by spinning it on its axis is interesting, why?”
View Don W's profile
Don W
9939 posts in 734 days
#4 posted 590 days ago
I’ve always used an insulated cabinet with a light bulb in it. I haven’t built one for my new shop yet, but I hope to before winter. I was hoping to find a small refrig or freezer not working, but no luck. Last winter I just brought them into the house.
View Grandpa's profile
Grandpa
2380 posts in 842 days
#5 posted 590 days ago
A 100 watt light bulb will keep an uninsulated box warm enough in SW Oklahoma so it would really keep a refrig warm enough. A metal cabinet with a light bulb would be enough. You can buy bi-metal wafers that act as thermostats. get a 38 degree for a 60 watt and a 34 deg for a 100 watt bulb. I have known people that have done this.
woodjunkie
#6 posted 590 days ago
Sorry Murdock. Hope you get some sleep!!!
