Is it possible to repair a laminated router table top?
Forum topic by stratiA posted 10-07-2011 05:47 AM 2666 views 0 times favorited 12 replies Add to Favorites Watch
View stratiA's profile
stratiA
101 posts in 3339 days
10-07-2011 05:47 AM
Hi everybody.
I am having a GOOD DAY. I got a tool gloat to share. My cousin who like me has to many hobbies is downsizing his shop. He gave me an older version Rockler router table and router lift. Unfortunately he put something wet on it one day and the table top has swollen at the miter track.!https://s3.amazonaws.com/vs-lumberjocks.com/lsofd81.jpg!
Is it possible to squeeze it back down. Maybe a little glue and a lot of clamping pressure will do it. Or do I sand or route it down and fit it a new piece of laminate over a small section. It is an older version and replacement tops for this older jess um plate isn’t available anymore. Worst situation would be to make a whole new top. Any suggestions will help. Thanks
-- Strati Alepidis, Burlington, Ma, Member Red Sox nation
12 replies so far
View vernonator's profile
vernonator
75 posts in 2615 days
#1 posted 10-07-2011 07:57 PM
could you not pop the laminate off the portion on that side of the miter track and re-attach (after repairing the underlayment)?
View PurpLev's profile
PurpLev
8534 posts in 3612 days
#2 posted 10-07-2011 08:04 PM
probably not worth it (financially and timewise). just get/make a new top.
View jeter's profile
jeter
20 posts in 2551 days
#3 posted 10-07-2011 09:44 PM
The best thing to do is
Remove the t-track and fill hole with a piece of wood 3/4’ x 3/8” x length and place another piece of MDF on top your damage table and laminate the new piece. To cut out the router plate opening before you glue up the new to the old one. Placing the old table on top of new one and trace out the cut. Use a trim bit with a bearing to make your opening.
View Lee Barker's profile
Lee Barker
2170 posts in 2814 days
#4 posted 10-07-2011 09:48 PM
I would salvage it this way:
I’d cut the offending section off just north of the T track.
Lay up a new piece and attach it flush as you can, using additional support underneath as you think you need.
Rout a new dado for the T track (using your router ta…oops.) right down the center of the joint and you’re back in business.
Kindly,
View Bill White's profile
Bill White
4901 posts in 3924 days
#5 posted 10-07-2011 09:56 PM
Replace the top with a new piece of laminate. I made my top with 2 pcs. of sink cut-out from a local cabinet shop. Glued ‘em back-to-back, routed the track grooves, etc.
Don’t spend too much time beatin’ a dead mule.
Bill
-- bill@magraphics.us
View Howie's profile
Howie
2656 posts in 2886 days
#6 posted 10-07-2011 09:59 PM
I’d go the route Lee suggested. For sure you won’t be out much except some time. Can’t see where it would be a big deal.
-- Life is good.
View Knothead62's profile
Knothead62
2584 posts in 2925 days
#7 posted 10-07-2011 10:38 PM
Go to a cabinet shop and get a piece of scrap countertop for practically nothing. I have three sink cut-outs for future projects- cost is $0! Cabinet shop tosses them in the dumpster.
View rance's profile
rance
4255 posts in 3124 days
#8 posted 10-07-2011 10:44 PM
Making a new one would be easier than your repair. And you’d be proud of it. Use the T-track off the old one.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2777 days
#9 posted 10-07-2011 11:04 PM
1+ on GrayPR comment. Keep the fence and the miter track and make a new top. Lowe’s has some nice laminate for $35
View buckles's profile
buckles
24 posts in 2505 days
#10 posted 10-07-2011 11:21 PM
You can get a bottle of Lacquer Thinner and use it to cut the contact cement that holds down the laminate. Sand or plane the base material flat and go to a cabinet shop. Pick up a scrap piece big enough to cover the old one, trim it on a table saw, glue it down and finish trim it with a file.
Regards
Joe
-- Politicians are like diapers. They need to be changed for the same reasons.
View MrRon's profile
MrRon
4710 posts in 3207 days
#11 posted 10-08-2011 09:32 PM
The “worst situation” is your best bet. The core is MDF or particle board and it looks from the picture that it is damaged, not just the laminate. You can try removing the laminate and see how the sub strait looks. If not damaged, re-laminate it.
View Chipy's profile
Chipy
374 posts in 2557 days
#12 posted 10-10-2011 10:35 PM
Belt sand it and re-lam it done!
