Installing Can Lights in Kitchen Ceiling
Forum topic by Carl Webster posted 10-06-2011 05:55 PM 1353 views 0 times favorited 8 replies Add to Favorites Watch
View Carl Webster's profile
Carl Webster
82 posts in 2729 days
10-06-2011 05:55 PM
I have a project to install several “can” lights in a kitchen ceiling. I am using a 6 inch + hole saw to cut the holes. The ceiling is sheeted with 1×4 tongue and grove pine and covered with ceiling tile. The hole saw is too large to use a standard 1/2 inch drill to cut the holes for the can lights. What type of drill should I use, maybe a 90 degree angle drill?
-- Carl in SC
8 replies so far
Carl Webster
#1 posted 10-06-2011 06:48 PM
The hole saw shank fits the 1/2 inch drill chuck. This is not the problem. The hole saw because of its diameter creates a large torque requirement against the drill motor and twists the drill out of my hands.
-- Carl in SC
View Blakep's profile
232 posts in 2733 days
#2 posted 10-06-2011 06:57 PM
Do you have a handle on your 1/2” Drill?
View Sawkerf's profile
1730 posts in 2999 days
#3 posted 10-06-2011 06:59 PM
Since you’re cutting through wood, there may not be a good way to keep a hole saw that big from twisting on you. Can you make the cuts with a jig saw? It isn’t as pretty, but it will work. Light cans usually have trim rings which will hide minor irregularities in the cuts.
Hopefully, you’re absolutely certain about your can locations. It’s fairly easy to fix an “oops” in drywall, but not so much in wood. (You may NOT ask how I know that. – lol)
-- Adversity doesn't build reveals it.
Carl Webster
#4 posted 10-06-2011 07:18 PM
Initially, I was not using the extra handle on my drill. I guess I should try that and see if that will resolve the problem. And yes I ended up using a jig saw to finish the first cut. It does not make as neat a hole as the hole saw.
-- Carl in SC
View Knothead62's profile
2581 posts in 2892 days
#5 posted 10-06-2011 09:39 PM
Just make sure that there is nothing in the way overhead like electrical wires. Mark the circle with the template that should be included and cut with a sheetrock saw. May take a few extra minutes and be a bit messy but a lot easier on the wrists.
18224 posts in 3607 days
#6 posted 10-07-2011 03:02 AM
I would use the hole saw to cut the tile, then use a sabre saw or something else ot cut the wood. That will burn up the hole saw in short order. Make sure you have clearances for the lights. They are a fire hazard.
View Grandpa's profile
3259 posts in 2606 days
#7 posted 10-08-2011 04:43 AM
Or get a drill motor with a D-handle on the back and insert a 3 or 4 foot pipe through it. Enlist some help and have a couple of guys hold the pipe while one operates the drill. I would think a lower RPM drill motor would work the best. I think my hole shooter runs 850 RPM. I have seen some in the 550 RPM range.
Carl Webster
#8 posted 10-08-2011 02:48 PM
Thanks for all your inputs.
-- Carl in SC
