| Forum topic by David Grimes | posted 591 days ago | 744 views | 0 times favorited | 4 replies | ![]() |
591 days ago |
Topic tags/keywords: phenolic baltic birch This is my first piece of this. I sure would like to know if there are any nuances of this material before I go ripping and routing it. Does it rip well ? Does it chip out badly ? How does it route ? Does it drill easily ? Etcetera.
Please share your experience. Thanks. -- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia |
#1 posted 591 days ago |
My experience is that it reacts like all other wood and all other ply – so zero clearence, if you need sharp cuts you can precut with a stanleyknife to prevent tear out. The ususal tricks. -- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking. |
#2 posted 590 days ago |
I don’t know if it was phenolic, but the last piece of 1/4 inch cherry “plywood” I used had some kind core that wasn’t wood, (may have been fiber core) but it worked great using the tools I normally use. -- Joe |
#3 posted 590 days ago |
I’m with mads. Its plywood. If you’ve worked with plywood you’ll see no difference. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#4 posted 590 days ago |
David, It will chip out when crosscutting. So, as Mads has pointed out, take appropriate steps. It routs fine. No different than other plywood. Start on the crossgrain side and work your way around. Just make sure you are using carbide bits as the resin plays hell on steel bits. As far as drilling goes, make sure you back up your hole with a piece of scrap. It will blow out, especially if you are using spade or forstner bits with larger holes. Cheers! -- Dave; Lansing, Kansas |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
