Cherry & PPB
Forum topic by DaveDelo posted 10-06-2011 03:26 AM 2021 views 0 times favorited 14 replies Add to Favorites Watch
View DaveDelo's profile
DaveDelo
86 posts in 2858 days
10-06-2011 03:26 AM
Topic tags/keywords: cherry
Bought about 1500bf of cherry a few months ago at an estate auction. Turns out the wood had been infected with powder post beetles. Even though I believe it wasn’t an active infestation, I didn’t want to take a chance on bringing it into the shop. Here’s my home-brew kiln solution that holds about 100bf at a time. Has two 375 watt heat lamps plus a fan. Takes about 4 hours to get to 120 degrees and 2 more hours to get to 140. I leave it on for 6 more hours with a final temperature of 155 degrees. From the research I’ve seen, 120-140 degrees for 4-6 hours kills all life stanges of the PPB.
14 replies so far
View ShaneA's profile
ShaneA
6909 posts in 2562 days
#1 posted 10-06-2011 04:10 AM
I guess with 1500 bf of cherry on the line, one will come up with some ingenious solutions. Looks like you are well on your way, congrats on the wood and good luck cooking the little buggers.
DaveDelo
#2 posted 10-06-2011 04:48 PM
Actually, the wood only cost 20 cents a BF but for some reason I just liked the color of this stack. Even though it’s been alot of work & hassle sterilizing it, machining it has revealed a very nice dark cherry color. Only solice is the auctioneer must have lost my check because its been 5 months and the check hasn’t cleared yet!
View SASmith               's profile
SASmith
1850 posts in 2951 days
#3 posted 10-06-2011 11:46 PM
Novel solution.
-- Scott Smith, Southern Illinois
ShaneA
#4 posted 10-06-2011 11:51 PM
That has to be an all time score, what a price! that could be the greatest $300 lumber purchase ever (assuming they cash the check) thats awesome, suppose you will be cranking out a lot of cherry projects?
View Nomad62's profile
Nomad62
726 posts in 2922 days
#5 posted 10-08-2011 12:29 AM
Specifically speaking, the core of the wood needs to get to 133 deg. f; the time involved depends on the thickness of the wood. If it is all 4/4, and there is air space between each piece, then you should be ok. Nice grab!
DaveDelo
#6 posted 10-08-2011 01:27 AM
I’ve got 3 thermometers inserted at 3 different depth levels into a 2×4. One all the way thru, one about 1/2” deep and the other 1” deep. Most of what I’m working with is 4/4 and some 1 1/8”. Temps vary from each other by about 2-3 degrees throughout the process. I wait to start the timer when all 3 get over 140 and then leave it for 6 full hours. After shutting off the power, the chamber still remains over 140 for another hour or so.
View JacksonLee's profile
JacksonLee
6 posts in 1409 days
#7 posted 06-12-2014 04:22 PM
Dave,
I’m in a similar situation with some hickory that is dry stacked. I bought some Boracare but want to make a small box like yours to bake the little buggers. What the demensions? Materials used? And where you happy with the results? I assume the fan is to keep the hot air moving, correct? Is there any issues with ruining the wood?
Thanks for any input.
View TheFridge's profile
TheFridge
9249 posts in 1450 days
#8 posted 06-12-2014 07:26 PM
A guy with a similar problem, but an active infestation in 14k$ cabinets, told me an ozone machine feeding a sealed room will kill anything and everything.
View WDHLT15's profile
WDHLT15
1731 posts in 2440 days
#9 posted 06-13-2014 01:02 AM
Yes, and the people in the house, too….....
View Yonak's profile
Yonak
986 posts in 1485 days
#10 posted 06-13-2014 05:02 AM
I’m loath to hijack this thread but in the OP, Dave said he didn’t want to bring the possibly infested wood into the shop for fear of infesting other wood. This is something I’ve been wondering about. Is there any evidence that the bugs can jump from one stack to another, as long as the infested wood is not stacked with uninfested wood ?
WDHLT15
#11 posted 06-13-2014 11:43 AM
Oh yes, when the adults emerge from the wood, they can re-infest that same wood, or they can fly to any nearby wood and infest that.
DaveDelo
#12 posted 06-13-2014 11:57 AM
Some of the web links I found back when I was researching this subject are no longer valid but here’s one with some decent information.
http://www.palletenterprise.com/articledatabase/view.asp?articleID=2890
WDHLT15
#13 posted 06-14-2014 01:03 AM
Dave,
Very informative article. I double treat my hardwood lumber. When green, it is sprayed with a borate solution. After some air drying, I kiln dry it, and at the end of the drying period, I run the kiln at 145 degrees for 24 hours.
I hate powderpost beetles. They are a scourge.
Yonak
#14 posted 06-14-2014 04:14 AM
“I double treat my hardwood lumber. When green, it is sprayed with a borate solution. After some air drying, I kiln dry it, and at the end of the drying period, I run the kiln at 145 degrees for 24 hours. ” – WDHLT15
..And even after all that, if the lumber returns to 9%~15% MC, it can still get infested, If I understand correctly. It doesn’t seem fair .. in fact, it seems downright insidious,
