removing bark?
Forum topic by JSilverman posted 10-04-2011 07:39 PM 1047 views 0 times favorited 5 replies Add to Favorites Watch
View JSilverman's profile
JSilverman
89 posts in 2638 days
10-04-2011 07:39 PM
A friend of mine has some small redwood logs that she would like me to help her turn into endtables by removing the bark and smoothing the sides and flattening the tops… I assume I can plane the tops and sand the sides… but I have never removed bark from a log without just cutting it off. Can anyone either suggest how to do it or point me to a resource on this?
thanks
Jeff
5 replies so far
View steviep's profile
steviep
233 posts in 2672 days
#1 posted 10-04-2011 07:51 PM
A Drawknife is the only way I know.
-- StevieP ~ Micheal Tompkins - you were not here on earth long but left a giant mark on us. RIP Brother
View Don W's profile
Don W
18754 posts in 2592 days
#2 posted 10-04-2011 09:02 PM
it really depends on the kind of tree and whether its green or dry. I’ve done it with a screw driver, a sharpened leaf spring off an old truck if its green. As Stevie suggested a draw knife will work. A wide chisel. They are make a deparker for a chainsaw tip. I’ve never used one, and not sure what the log looks like after. Baileys debarker . You can find these on ebay as well.
View greg48's profile
greg48
601 posts in 2782 days
#3 posted 10-04-2011 10:05 PM
If you are in no hurry, let them overwinter outside. Then you can peel it with your fingers.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View Arminius's profile
Arminius
304 posts in 3828 days
#4 posted 10-05-2011 01:02 AM
Use a hatchet, ideally a side axe (bevel on only one side) to get most of the bark mass off, drawknife to clean it up. I would recommend a well-sharpened drawknife over sanding the sides if you are looking for a rustic log finish.
View meikou's profile
meikou
115 posts in 3660 days
#5 posted 10-05-2011 01:07 AM
my Sensei uses a pressure washer to strip bark off of cedar
