Dust Collection Questions
Forum topic by laxbograt posted 10-04-2011 04:50 PM 1253 views 0 times favorited 6 replies Add to Favorites Watch
View laxbograt's profile
laxbograt
76 posts in 2667 days
10-04-2011 04:50 PM
I have a couple questions regarding dust collection / collectors. I recently bought a used 1hp dc, it is definitely an upgrade from the shop vac, but I was wondering are there any upgrades I could do to increase its performance, ie motor size, etc…
Also I have already upgraded to a .5 micron canister filter.
Thanks for the info
Carlos
View ClayandNancy's profile
ClayandNancy
520 posts in 3255 days
#1 posted 10-04-2011 05:25 PM
Best addition to your DC would be aThein separator. The separator removes the bulk of the sawdust so large pieces don’t go thru the impeller on your DC. Also lessens the dust in your filter. Just google Thein separator or search here on LJ’s, you’ll find a lot of onfo.
View Sawkerf's profile
Sawkerf
1730 posts in 3309 days
#2 posted 10-04-2011 06:37 PM
Unfortunately, your options are somewhat limited. A 1hp DC is pretty much at the low end of the spectrum. Going to the 0.5 micron filter bag is a good thing, but it also reduces the flow rate thru the system. Going to a bigger motor probably wouldn’t help a lot since the impeller is what really provides the flow.
Rather than spend a lot of time and money trying to jack up the performance of yours, you would probably be better off to sell it and get a bigger DC. The Harbor Freight DC is very inexpensive and gets great reviews.
laxbograt
#3 posted 10-04-2011 06:55 PM
You mean to tell me my Delta 1 HP Dust Collector would be outperformed by a Harbor Freight Dust Collector.
like this:
“http://www.harborfreight.com/2-hp-industrial-5-micron-dust-collector-97869.html”
My whole foundation is shaken, when Harbor Freight is better than Delta
Carlos
View agallant's profile
agallant
551 posts in 3127 days
#4 posted 10-04-2011 07:28 PM
I have not heard too many good things about the lower end Delta DC.
ClayandNancy
#5 posted 10-04-2011 07:49 PM
The HF DC is pretty well liked around LJ’s. It’s suppose to be a 2 hp, not likely, but still a good dust collector. You can get a 20% off coupon in some mags like Wood. I lucked out and got a Clearvue cyclone for about a 1/3 the price.
View jeth's profile
jeth
262 posts in 3078 days
#6 posted 10-04-2011 09:02 PM
I don’t think it comes down to HF being better than Delta, a DC is very simple, a motor, impeller and bags for filtration/collection. The 2HP machine has a bigger motor (and most likely a bigger impeller to match), so it will move more air, and therefore more dust/chips, which is what you want from a DC. The machines are often near identical in construction so higher power=greater suction, simply put.
