Woodturning Finishes
Forum topic by micbora posted 10-01-2011 11:37 PM 1578 views 0 times favorited 7 replies Add to Favorites Watch
View micbora's profile
micbora
26 posts in 2539 days
10-01-2011 11:37 PM
Topic tags/keywords: question finishing turning
Hi all, just wanting to get some tips on finishes for turnings, what are the different types and what results would they give?
-- Michael, N.Ireland
7 replies so far
View hairy's profile
hairy
2701 posts in 3526 days
#1 posted 10-01-2011 11:40 PM
micbora
#2 posted 10-02-2011 02:13 AM
Thanks Hairy
View KayBee's profile
KayBee
1083 posts in 3240 days
#3 posted 10-02-2011 02:28 AM
I know General Finishes just came out with Wood Turners Finish (WTF). Most likely not available to you over there. More helpful to you is that it’s supposed to be their varnish finish, just diluted.
-- Karen - a little bit of stupid goes a long way
View willie's profile
willie
533 posts in 2448 days
#4 posted 10-03-2011 01:29 AM
I use spray lacquer on most of my projects including turnings. I spray on the lathe when I can. The trick is LIGHT coats. Take your time and build your finish. Buff with 0000 steel wool between coats. I usually put a coat of paste wax on top of the lacquer and buff to a nice gloss. I’m sure you’ll get many ideas for finishes and everyone has their favorite! Experiment and have fun.
-- Every day above ground is a good day!!!
View wisno's profile
wisno
88 posts in 3004 days
#5 posted 10-03-2011 06:44 AM
The turning is the end grain. It will absorb more finishing material.
When you apply your stain, avoid too wet spray. Since it tends to absorb more stain and make darker color.
If you spray the coating, then you need more layer to make smooth surface finish.
Thanks
good luck
-- http://www.wisnofurniturefinishing.com/
micbora
#6 posted 10-05-2011 11:09 PM
Thanks everyone, I think i’m going to start with Danish oill in the mentime, keep it simple to start with and then try other finishes after that.
View Guss's profile
Guss
94 posts in 2434 days
#7 posted 10-06-2011 05:12 AM
I have had good luck with carnauba wax for a good gloss but the finish is not that durable. I have had good luck with the EEE-Ultra Shine then Shellawax to for a high gloss finish. For a satin finish i have used the Hut brown bar. I have started using the Mylands 3 Step Finishing System and I really like it. I put a danish oil on all of the stuff I turn I like how it brings out the colors of the wood.
