Foolish mistake (screws through the benchtop)
Forum topic by Murdock posted 10-01-2011 06:33 AM 2063 views 0 times favorited 16 replies Add to Favorites Watch
View Murdock's profile
Murdock
129 posts in 2655 days
10-01-2011 06:33 AM
Topic tags/keywords: workbench fir plywood question
I attempted to attached the top of my new workbench tonight and now have screws sticking up through it, the pointy end.
I used pocket holes from the bottom with 2.5” screws, the rails are fir 2x and the top is 2 layers of 3/4 plywood.
I did several test pieces before I began and should have had the screws ending 1/4” before coming through but it turns out that the rail material was softer than I expected and I ended up driving the screws all the way through the top and now they stick out by 1/8 and 1/4 inches. Of course I had the whole unit upside down while doing this so I didn’t notice it until I turned it over and cut myself on one of the screws.
If I back out each of the screws and put a shorter one in the same hole can I expect it to hold, or will the hole be large from the original screw?
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
16 replies so far
View rance's profile
rance
4264 posts in 3331 days
#1 posted 10-01-2011 06:47 AM
I’d certainly try replacing them with shorter screws. If the holes can’t be HEALED, then you may be adding a new ‘feature’ on the other side. Oh, and for that softer material, soak the material with CA glue to harden it up a bit after removing the long screw & healing the holes, but before installing the shorter screws.
Hey, little butterfly inlays might look right nice on that top.
View tomd's profile
tomd
2170 posts in 3941 days
#2 posted 10-01-2011 06:51 AM
Slip a sliver of softwood into the holes after you remove the long screws to take up any slack.
-- Tom D
View ocwoodworker's profile
ocwoodworker
209 posts in 3175 days
#3 posted 10-01-2011 06:51 AM
The tapered tip is only a short portion of the screw. You should be able to shorten the screw and not have a problem.
If you find that it is too loose you could always ream the hole and insert a glued dowel and then re-drill the hole. Hope it all works out.
Cheers
-- I'd like to believe Murphy's Law haunts my woodshop, because if it's Karma it would mean I had something to do with it. - K.R.
Murdock
#4 posted 10-01-2011 07:35 AM
Thanks for the help guys, I am going to pick up the shorter screws tomorrow and give it a go.
View Loren's profile
10477 posts in 3819 days
#5 posted 10-01-2011 02:27 PM
Bolt cutters are useful for shortening screws. In cabinet work, screws are
needed in such fine increments for so many specific applications, it is hard
to keep all sizes on hand and some very useful screws aren’t available at
normal hardware stores. Thus the art of screw-cutting. As long as you’ve
got a pilot hole, the screw doesn’t need a pointy end.
View saddletramp's profile
saddletramp
1180 posts in 2809 days
#6 posted 10-01-2011 02:34 PM
Can you go with a shorter, one size larger screw?
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
Murdock
#7 posted 10-01-2011 02:43 PM
Loren – good idea but no bolt cutters
Saddletramp – Also a good idea, I’ll see what they have for diameters at the local hardware.
Thanks
#8 posted 10-01-2011 03:04 PM
Hardened screws can usually be broken off pretty easily as well, in
a pinch. This comes up on installations and other jobsite work often
enough.
View Sawkerf's profile
Sawkerf
1730 posts in 3239 days
#9 posted 10-01-2011 03:43 PM
Sounds like you over-drove your screws. Did you lower the setting of the drill clutch? I usually set mine to 12 – 14 depending on the hardness of the wood. You want the screws to seat firmly, and then stop.
Were you using the right pocket screws? The Kreg system uses truss head screws (the screw heads look like they have a washer). I once tried to use a different type of pocket screw and had a problem similar to yours.
You can probably save your work by backing out the screws, gluing a filler like a matchstick into the threaded part of the hole, and carefully re-driving your screws.
Murdock
#10 posted 10-01-2011 04:20 PM
Sawkerf
I no doubt over-drove the screws. The clutch on my drill is stiff so I had it set to 8, but it never triggered, I stopped when it “snugged up”
I was using the Kreg brand screws, they happen to be the “weather resistant” kind since I had some left over from making window flower boxes last year.
The matchstick or larger screw size is what I am going to try, headed to the store now to get the shorter screws
View jusfine's profile
jusfine
2422 posts in 3097 days
#11 posted 10-01-2011 05:06 PM
You can also use a belt sander to shorten them.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
Murdock
#12 posted 10-02-2011 03:17 AM
The shorter screws seem to be working great, top is showing no signs of being loose and the holes are hardly noticeable as the closed up on themselves as the screws were removed.
Thanks again for all your suggestions
View StumpyNubs's profile
StumpyNubs
7674 posts in 2971 days
#13 posted 10-02-2011 03:40 AM
Just plane them smooth with a good hand plane…
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View David Grimes's profile
David Grimes
2078 posts in 2810 days
#14 posted 10-02-2011 04:40 AM
... or nearly smooth with a bad hand plane.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View AlbertaJim's profile
AlbertaJim
47 posts in 2600 days
#15 posted 10-02-2011 04:44 AM
If the old holes do bother you you could always make new pocket holes from the bottom side and then cut some plugs from a contrasting wood and make the old holes a design feature.
-- My Boss was a carpenter
