Bandsaw out of whack?
Forum topic by Spoontaneous posted 09-29-2011 04:01 AM 1376 views 0 times favorited 7 replies Add to Favorites Watch
View Spoontaneous's profile
Spoontaneous
1334 posts in 3328 days
09-29-2011 04:01 AM
Back at the first of the year I bought one of those Grizzly 14” band saws. It has been doing fine until recently. I noticed a sound…. sort of ticking…. then it got to knocking. I figured out today that as I turn the wheels with tension on… one of the spokes on the bottom wheel is nicking against the motor spindle (or whatever that black rod is).
I always release the tension on the saw at the end of the day… and the blade seems to be tracking mostly in the middle. Is there a way to shim up the lower wheel or something I can tighten… or loosen in order to have it hum again. I would appreciate any advice. I’m not too technical with these machines…. they run until they don’t. Thanks!
-- I just got done cutting three boards and all four of them were too short. (true story)
7 replies so far
View mtnwild's profile
mtnwild
3474 posts in 3525 days
#1 posted 09-29-2011 04:32 AM
Sounds like a bearing going out. Don’t know if that’s a replacable part. Maybe a new wheel?
Spoontaneous
#2 posted 09-29-2011 04:42 AM
I hate to think ‘those’ thoughts. It is only 9 months old and I use it maybe 2 hours a week… if that. I was hoping for something like a loose bolt. <grin> But thanks!
View gfadvm's profile
gfadvm
14940 posts in 2688 days
#3 posted 09-29-2011 04:42 AM
Call the Grizzly tech support guys. They always seem to have the right advice and have solved problems for me that I had wrestled with for days.
Spoontaneous
#4 posted 09-29-2011 12:05 PM
Thanks guys ~ I will check those bolts and then use a level to make sure the wheels are aligned. If that fails me, I will go ahead and call those fellers at Grizzly. Thanks again.
View Blakep's profile
Blakep
232 posts in 2800 days
#5 posted 09-29-2011 01:54 PM
Just make sure your hurry up and find the problem because it probably has a 1 year warranty on it. That way if it is the bearing then they can replace the wheel at no cost to you. I bought my saw around the same time as you and I have had some minor issues but for the time being it is running great. I agree to try tuning it first and see if that helps.
View Roger's profile
Roger
20928 posts in 2802 days
#6 posted 09-29-2011 02:04 PM
definately what vonhagen said. I’d get the manual out, and start from the beginning to “tune” and align everything up. sounds like something has come loose
13603 posts in 3339 days
#7 posted 09-29-2011 02:47 PM
try this
http://blip.tv/the-wood-whisperer/episode-13-bandsaw-set-up-tune-up-189378
