24 inch omnijig help
Forum topic by waldo posted 09-28-2011 07:40 PM 1233 views 0 times favorited 5 replies Add to Favorites Watch
View waldo's profile
waldo
36 posts in 2520 days
09-28-2011 07:40 PM
I need some help…. I just recently bought the 24 inch omnijig, upgrading from my 12 inch fixed PC jig. The issue that I am having is that I don’t know where the offset needs to be in relation to the fingers for single pass half blind. I have played with this jig for roughly 2 hours and can’t get it worked out, the dovetail fit etc. is flawless, but the drawer bottoms/tops are offset enough that there’s no way to run a groove to accept a plywood bottom. Any help would be great.
-- One miscut away from firewood...
5 replies so far
View jusfine's profile
jusfine
2422 posts in 2795 days
#1 posted 09-28-2011 10:59 PM
Do you have the PC video that explains everything?
I figured my jig and spacings out from watching the video a few times.
I have the old heavy cast iron one, probably 20 years old, you have a newer model?
-- Randy "You are judged as much by the questions you ask as the answers you give..."
waldo
#2 posted 09-29-2011 08:23 PM
Hey! I do have the PC video and have talked to the Rep. apparently my offset guide is off, but to answer your questions, I do have the newer model.
jusfine
#3 posted 09-30-2011 03:50 AM
Hope you can get it going!
I am having fun learning my Leigh jig now.
All the Best!
View Howie's profile
Howie
2656 posts in 2792 days
#4 posted 09-30-2011 04:30 AM
I put an old TV and VCR/CD player in my shop. I’ve found out it seems to work better for me if I watch the Vids, pause, do what ever they are doing and then continue the vid.
You can buy both cheap at thrift stores if you don’t have one laying around.
One other tip, keep them covered they don’t like sawdust.
Good luck on your jig,I’m sure you will figure it out.
-- Life is good.
waldo
#5 posted 10-01-2011 12:14 PM
Well, I talked to the PC rep. They are sending me out a new offset guide, mine is off by about 1/16 or so. I can get everything right if I don’t use the guide, but for repeatability it’d be nice to have. Thanks everyone for the thoughts!!
