Walnut Warning just fyi
Forum topic by tinman_362 posted 09-27-2011 11:44 PM 1167 views 0 times favorited 3 replies Add to Favorites Watch
View tinman_362's profile
tinman_362
95 posts in 2600 days
09-27-2011 11:44 PM
Topic tags/keywords: walnut
Thousand Cankers Disease in Pennsylvania Trees
HARRISBURG, PA. —Thousand Cankers Disease has been detected for the first time in Pennsylvania, and a quarantine restricting the movement of wood from Bucks County and other states known to have the disease is effective immediately.
The disease is caused when Walnut Twig Beetles, which carry a fungus, tunnel beneath the bark of walnut trees, causing small cankers to form. As more beetles attack the tree, the number of cankers increases, slowly starving the tree of nutrients and causing the tree to die within 10 years of initial infestation. There is no known cure.
The disease was found on a black walnut tree in Plumstead Township, Bucks County, and reported by the property owner to Penn State Cooperative Extension. The sample was verified by the state and federal Departments of Agriculture.
“Thousand Cankers Disease poses a significant threat to Pennsylvania’s $25 billion hardwoods industry,” said Agriculture Secretary George Greig. “To help ensure this disease does not spread to other regions throughout the state, I urge Pennsylvanians to comply with the quarantine restricting the movement of wood from Bucks County.”
The quarantine restricts the movement of all walnut material including nursery stock, budwood, scionwood, green lumber and firewood. It also covers other walnut material—living, dead, cut or fallen—including stumps, roots, branches, mulch and composted and uncomposted chips. Due to the difficulty in distinguishing between species of hardwood firewood, all hardwood firewood is considered quarantined.
The quarantine also restricts the movement of walnut material and hardwood firewood from states known to have Thousand Cankers Disease, including Arizona, California, Colorado, Idaho, Nevada, New Mexico, Oregon, Tennessee, Utah, Virginia and Washington.
Nuts, processed lumber and finished wood products without bark are exempt from the quarantine.
Failure to follow the quarantine order could result in criminal penalties of up to 90 days imprisonment and a fine of up to $300 per violation, or a civil penalty of up to $20,000 per violation.
Since many species of wood-boring insects, including the Walnut Twig Beetle and Emerald Ash Borer, can be spread through transport of infested firewood and logs, campers and homeowners are encouraged to use only locally harvested firewood, burn all of it on-site and not carry it to new locations.
Thousand Cankers Disease was first diagnosed in walnut trees in Colorado in 2003, and has caused widespread death of black walnut trees in many western states. Other species such as Arizona walnut, English walnut and California walnut have shown varying degrees of susceptibility to the fungus.
Adult walnut twig beetles, native to the southwestern United States and Mexico, carry spores of the Geosmithia fungus, which is introduced to the tree as they bore under the bark. The beetles are extremely difficult to detect as they are dark brown and similar in size to a poppy seed.
Early symptoms of the disease are yellowing of leaves and foliage-thinning of the upper crown of the tree. As the disease progresses, larger limbs are killed followed by the trunk.
The Pennsylvania Department of Agriculture will work with other state and federal agencies and Penn State to survey for walnut twig beetles to slow the spread of Thousand Canker Disease.
Black walnut trees, which make up less than half of one percent of hardwood trees in Pennsylvania, produce high-valued lumber used in woodworking and furniture-making. The nuts of the trees are consumed by humans and wildlife.
People who suspect they have seen Thousand Cankers Disease or walnut twig beetles should contact their local county cooperative extension office or call the department’s automated toll-free pest hotline at 1-866-253-7189.
For more information about Thousand Cankers Disease, visit www.agriculture.state.pa.us.
-- Robert: Life is all about the stories ~
3 replies so far
View juniorjock's profile
juniorjock
1930 posts in 3794 days
#1 posted 09-29-2011 02:04 AM
Thanks Robert. I think this is one of the most informative post I’ve seen on LJ.
- JJ
View EPJartisan's profile
EPJartisan
1118 posts in 3154 days
#2 posted 09-29-2011 03:43 AM
WOW.. I had no idea.. I love this site! Thank You!
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
View BTKS's profile
BTKS
1986 posts in 3493 days
#3 posted 10-06-2011 05:03 AM
Thanks for the info. I recall seeing a no transport warning coming out of the west but this is the first I’ve heard of quarintine from the eastern U.S.
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
