Doweling on router table
Forum topic by niki posted 1033 days ago 1937 views 0 times favorited 7 replies Add to Favorites Watch
Rockler
View niki's profile
niki
429 posts in 1051 days
1033 days ago
Good day
Yesterday, I posted my crazy router table.
Today, I would like to share with you my way of drilling dowel holes for a frame that works the same way also for carcass just by using more “Spacers”.
First, I decide the depth of the hole and I set and lock the depth-stop.
Second, I set the fence so the hole will be drilled at the center of the wood thickness but, it’s not so important if the hole is not exactly at the center.
The above two steps are not shown on the pics.
The rest of the story is on the pics
Regards
niki
View coloradoclimber's profile
coloradoclimber
478 posts in 1039 days
1033 days ago
Niki,
This is excellent. I don’t know that I’ve seen this sequence of setup steps, simple fixtures, and offset blocks before. Your methods looks simple, clean, and accurate.
I think this would work well for cutting mortises. Use an offset block the width of the mortise, plunge to start the mortise, remove the offset block, rout over to the stop block, finished.
I think perhaps I’ll give this a try this weekend.
thanks for posting
28894 posts in 1372 days
1033 days ago
This is great Niki, Another great tip.
View Bill's profile
Bill
2553 posts in 1132 days
1032 days ago
Another winner Niki. Like CC said, you almost have your own mortise machine already built.
Keep those jigs and pictures coming.
View niki's profile
niki
1032 days ago
Thank you so much for your kind replies
Coloradoclimber
You are correct, it works very good for mortising just that my router is not so strong and cannot take all the depth in one pass, so I’m doing it in a few passes or, I’m making a series of overlapping holes (you can make as many as you want) and than clean the mortise.
I’m using two stops (start & end) even when the board is 3, 4 or 10 feet.
Another possibility is to use the “floating tenon” or “loose tenon” or whatever it’s called (I mean like the Festool Domino does).
niki
View JonH's profile
JonH
55 posts in 1057 days
1032 days ago
Niki, Excellent idea with the doweling on the router table! I have one idea that could make it even better. If you took a router bit that is used for making V grooves (or any pointed bit), you could load it in your router, and raise the bit up and mark on your table where the center of the hole is. The point on the bit will tell you exactly where the center is, so all you have to do is mark your pieces in any pattern, and all you have to do is line up the mark on the board and on the table and drill the hole. Once you have your mark, you can install whatever size bit you want, and it will be centered on the mark you have made on your table. No stop blocks needed! The only adjustment needed would be for the thickness of the wood, and you have to make that adjustment now anyway. If you used a toggle clamp to hold the workpiece down, you could cut your mortises hands free! Good luck!
View niki's profile
niki
1032 days ago
Thank you JonH
I could not understand your idea with the V groove bit.
If you mean to make a pencil mark 90° to the fence at the center line of the bit, I think that it will lead to some small mistakes in the holes locations.
If you try, you will see that locating the stop and the spacer takes a minute and I think that it’s more “Idiot proof” (for me).
Toggle clamps is very good idea but I cannot find them here in Poland (in USA you can find them in any orange box) but even holding the work with the hands is not a problem for me.
niki
View WayneC's profile
WayneC
6335 posts in 1068 days
1032 days ago
Thanks Niki. Excellent info and clear instructions as ususal.
