Any experience with this wet/dry grinder?
Forum topic by thetree posted 09-26-2011 09:06 PM 1421 views 0 times favorited 9 replies Add to Favorites Watch
View thetree's profile
thetree
17 posts in 3003 days
09-26-2011 09:06 PM
Found this wet/dry grinder on sale at enco. For the money it might not be a bad “roughing” grinder for plane blades and chisels. Please give me your opinions if you have seen one or used one. Thanks!
-- www.sutterlinmachine.com
9 replies so far
View PurpLev's profile
PurpLev
8535 posts in 3648 days
#1 posted 09-26-2011 09:13 PM
I think Delta or Makita used to sell those, dont see them much these days though.
I like the sheppach (grizzly sells same one) which is a cheaper version of the Tormac and Jet slow grinder. it works great and leaves a slight hollow on the edges which lets you then easily hone them freehand at your bench as needed.
View Don W's profile (online now)
Don W
18715 posts in 2567 days
#2 posted 09-26-2011 09:53 PM
I have a Makita that is similar. Its great for planer and jointer blades, but I don’t like it for planes or chisels.
thetree
#3 posted 09-26-2011 10:31 PM
Care to elaborate why you don’t like it for planes or chisels? I will be hand finishing them on water stones, I just need a grinder with a nice tool rest to create a decent “hollow” on the blade/chisel.
Don W
#4 posted 09-26-2011 10:45 PM
Thats number one, it doesn’t create a hollow, and its slow, and my shop is unheated so it can’t stay there. I find a bench grinder with a simple homemade rest and an aluminum oxide wheel works best. Here's how I sharpen planes.
thetree
#5 posted 09-26-2011 11:10 PM
Please explain how an 8 inch wheel can create more of a hollow than a 5 inch wheel? Also, an 8 inch wheel will hve a MUCH higher surface speed than a 5 inch wheel, and without a water drip, seems like it would have a higher tendency for burning. What am I missing here?
Don W
#6 posted 09-26-2011 11:13 PM
should be less of a hollow.
thetree
#7 posted 09-26-2011 11:29 PM
I don’t understand. Are you saying it creates too much of a hollow, or none at all? Your previous post states “thats number one, it doesn’t create a hollow”.
Don W
#8 posted 09-27-2011 12:28 AM
The grinder you show uses a horizontal wheel, it will not produce a hollow, you will be sharpening on the flat part of the wheel. I personally like a hollow grind.
thetree
#9 posted 09-27-2011 12:37 AM
You are mistaken, sir.
