| Forum topic by oldfolks | posted 590 days ago | 310 views | 0 times favorited | 8 replies | ![]() |
590 days ago |
590 days ago |
what sort of things are you looking to do with a table saw. like what will you use if for most often. i think that that will help to try and figure out what saw is right for what you plan on doing with it. |
590 days ago |
You might keep an eye out on Craig’s List in your area. I live somewhat near Sacramento and there are always a ton of woodworking tools there. Since the housing flop has hit I have seen entire cabinet shops closing business and selling everything. There was a hardware store north in Red Bluff that closed it’s doors (bankrupt) after 50 years of business. Auctioned everything off. -- Scott - Chico California http://chicowoodnut.home.comcast.net |
590 days ago |
dremel should work fine for small projects.. Check the paper and e bay.. craigs list and more… there is more out there at a good price -- making sawdust.... |
590 days ago |
I picked up a 12 inch craftsmen tables saw on craigslist for 50 bucks. Added on a vega fence for 270 and i’m good to go. I should say I’m good to go friday when the fence gets here. |
590 days ago |
Craigslist or local auctions. I am amazed at what you can get for only a few bucks. Older Craftsman tables are really good, but I have one so I am partial to that brand. I also had a Delta 10” that was a direct drive (no belt – motor turned the blade) table saw that I could not over-work. You mentioned a fixed income so the the power-matics may be out of reach, but if you get a chance I wouldn’t turn it down. Used is definately the way to go as long as used is not abused. Good luck. -- Brian, Lebanon PA, If you aren’t having fun doing it, find something else to do. |
590 days ago |
For my first table saw I took 2 free standing cabinets about 2-1/2 or 3 ft apart and put an discarded laminated counter top on top of the two, cut a hole in the middle and mounted an old (the all steel construction) craftsman skill saw mounted on a Plexiglas throat plate and dropped it in upside down, this also served as my first router table. Very rudimentary but it worked until I picked up an inexpensive contractor’s table saw that I still use. -- Craig Barton, DFW, TX |
589 days ago |
I mounted a skill saw upside down on some ply wood for my first table saw -- bryano |
589 days ago |
Great idea Craig! I find myself in the same boat as “oldfolks”.... May have to go that route… pardon the pun… LOL -- Cheers! |
| Forum | Topics |
Woodworking Skill Share
2921 |
3949 |
257 |
950 |
225 |
Woodworking Trade & Swap
620 |
Coffee Lounge
2394 |
LumberJocks.com Site Feedback
524 |
