tension spring for delta 28-560
Forum topic by Razorbak91313 posted 09-26-2011 06:21 PM 1757 views 0 times favorited 6 replies Add to Favorites Watch
View Razorbak91313's profile
Razorbak91313
89 posts in 2671 days
09-26-2011 06:21 PM
I have a Delta 28-560 and I was looking to get a new tension spring but Delta discontinued it and I can’t seem to find anyone that has them. It looks like I can use just about any brand/type as long as it it the right length and diamater to fit. Can someone confirm if I am correct in that assumption?
-- Turning good wood into even better wood jewelry. DWWoodCreations.com
View Chris 's profile
Chris
1879 posts in 4018 days
#1 posted 09-26-2011 06:43 PM
I recently replaced the spring in my Jet Bandsaw with one of these and it worked wonderfully. If your model is a 14” saw you should have no issues.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View Don W's profile
Don W
18754 posts in 2594 days
#2 posted 09-26-2011 07:10 PM
woodcraft sells aftermarket springs for most saws.
Razorbak91313
#3 posted 09-26-2011 08:16 PM
Thanks everyone. I will check woodcraft and see if they have any recommended replacements for the model bandsaw, otherwise I will order based on the spring size that is currently in there.
View ChefHDAN's profile
ChefHDAN
1067 posts in 2876 days
#4 posted 09-26-2011 09:40 PM
i put the Cobra Coil in my 14” works better than the stock spring.
http://www.carterproducts.com/product.asp?product_id=155&cat_id=16
View quartrsawn's profile
quartrsawn
146 posts in 3240 days
#5 posted 09-26-2011 09:55 PM
try….. www.ereplacementparts.com ....
-- Nat - West Sayville,L.I., NY
View JSilverman's profile
JSilverman
89 posts in 2640 days
#6 posted 09-26-2011 11:54 PM
have you looked at Iturra?
they make very good replacement parts for bandsaws
