Dovetails in extremely splintery hardwood?
Forum topic by Chelios posted 09-26-2011 01:25 AM 975 views 0 times favorited 5 replies Add to Favorites Watch
View Chelios's profile
Chelios
568 posts in 3035 days
09-26-2011 01:25 AM
Topic tags/keywords: question
Any of you have experience cutting dovetails in real splintery wood like cocobolo, zebrawood, or the like?
I have my last little board of cocobolo that I thought could make a nice little dovetailed box but I am afraid the tails are going to be very hard to keep clean.
thanks as always
5 replies so far
View Dallas's profile
Dallas
3599 posts in 2456 days
#1 posted 09-26-2011 01:50 AM
When I was making some dovetails on some Chinese mahogany, I had to put a backer and a face board made of scrap oak I had laying around.
The mahogany would blow out front and back even when I used a plywood face and backer.
I don’t know it that’s the right way to do it, but it worked for that job.
Chelios
#2 posted 09-26-2011 01:53 AM
Good idea thanks. I assume you were using a dovetail ji/router? Same principle might apply for hand cut?
Dallas
#3 posted 09-26-2011 04:08 AM
No, I was cutting them by hand with a fine tooth back saw and cleaning up with chisels. The job ended up looking good, but I have to confess, I’ve only done a few more since then and they weren’t anything to brag about.
If I hadn’t had to the first ones, I probably still wouldn’t do them.
(I also have a jig and router to make them, but it’s been collecting dust since about 2007!)
View Dark_Lightning's profile
Dark_Lightning
3146 posts in 3077 days
#4 posted 09-26-2011 04:09 AM
Since you would only be cutting on the push or the pull (depending on the type of saw) you would only need a backer board on the “away” side of the cut. I use a jig. I don’t have the time for hand-cut dovetails. YMMV.
-- Random Orbital Nailer
Chelios
#5 posted 09-26-2011 05:06 AM
Thank you for the great tips. I am going to try them now. I plan on taking my time on this.
