Mortise, tenon and maybe epoxy?
Forum topic by Broglea posted 604 days ago 1164 views 0 times favorited 15 replies Add to Favorites Watch
View Broglea's profile
Broglea
654 posts in 1259 days
604 days ago
Hey guys. Looking for a little guidance here. I’m getting ready for the final glue up of a storage bench and noticed that a few of the joinery is really loose. I didn’t do the best of job with some of the mortises and the tenons are loose.
Should/can I use epoxy in these joints to fill in some of the gaps or just use titebond. I’d really hate for the thing to come apart in a few years. I’m leaning towards epoxy. Thanks
15 replies so far
View maljr1980's profile
maljr1980
171 posts in 624 days
#1 posted 604 days ago
id use liquid nail/pl 400 construction adhesive for the joint in this case
Broglea
#2 posted 604 days ago
Liquid nail is something I would not have thought of. Not the norm, but may be the ticket.
maljr1980
#3 posted 604 days ago
yeah i know, but it goes on pretty thick and dries really hard, id be afraid of filling with an epoxy and not getting a strong bond
View DaleM's profile
DaleM
800 posts in 1552 days
#4 posted 604 days ago
I have used my bandsaw to cut very thin laminates of wood in the past and glued them on to the tenons. I’ve also used the thin shavings I’ve made with my handplanes and glued them on to the tenons if I just needed it a little more snug.
-- Dale Manning, Carthage, NY
Rick Dennington
2889 posts in 1363 days
#5 posted 604 days ago
I agree with DaleM on fixing the tenons by using thin laminates or shims. I’ve did exactly the same thing. I’ve even used a brown paper bag, cut off a piece, and wrapped it around the tenon. It depends on how snug or tight you want the tenon… Don’t make it too tight, and save some room for glue. I’m not too sure about the liquid nails idea. Might work….who knows…...
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
27262 posts in 1990 days
#6 posted 604 days ago
+1 on Rick’s idea of using brown paper shims to tighten up the m&t fit. Gluing the shims to the tenon adds a few thousandths to the width of the tenon that can be easily sanded to give a snug fit.
View jevarn71's profile
jevarn71
80 posts in 1328 days
#7 posted 604 days ago
I wouldn’t use the brown paper as shims. I would use the wood shims however. The way wood glue works it will form a stronger bond. All else fails after you shim it to tighten the joint, use drawbore pins to lock it up for good.
-- Jason - Aim High!!
View rusty2010's profile
rusty2010
124 posts in 726 days
#8 posted 604 days ago
Definety do what Jason said. I been there before and it works.
-- check, recheck then check again
View tenontim's profile
tenontim
2129 posts in 1913 days
#9 posted 604 days ago
I keep an assortment of the sides that are cut off of the tenons that I cut. If I get one that’s too loose. I glue the pieces back onto the tenon, and recut the tenon to the correct thickness.
-- Tim-- http://www.tmuli.com
Broglea
#10 posted 604 days ago
I thought of the shim solution after I posted the question. Thanks for the reponses everyone. The liquid nail comment is interesting.
View Jonathan's profile
Jonathan
2568 posts in 1219 days
#11 posted 604 days ago
I’d also be inclined to shim the tenon by gluing on a thin piece of stock, then sanding or planing it until you’ve got a nice snug fit, again leaving a little room for glue, as others have said.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View 000's profile
000
3352 posts in 785 days
#12 posted 604 days ago
I’d not rely on epoxy to fill in a sloppy joint. Rather I’d use wood glued to the parts that are too skinny.
I’d especially not rely on any of the construction adhesives because I wouldn’t trust them to cure hard.
I think they are engineered to remain flexible. So unless flex in the joint is desired ~ ~ ~ ~ ~
you can always make your tenon thicker by gluing some wood to it. Then use a hand plane and chisel to get it to the fit you want.
Joinery is not hopeless until after the glue sets.
You can always add and remove stock where you need it.
-- When the moderator chooses sides, his site sucks.
View reggiek's profile
reggiek
2238 posts in 1438 days
#13 posted 604 days ago
Two problems with epoxy – sheer and heat. Epoxy will let go if you subject it to high heat (has to be pretty hot – but I have had things let go in my shop when the temperature outside is 102+). Sheer is a force that is not parallel to the seam – if the joint is going to have side to side stress you would be better suited gluing the joint as is and then using the epoxy as a filler.
I would go with the wood shim filler myself. I have had to resort to this kind of fix to repair mistakes and slips of the blade or chisel when making the Mortise or Tenons – I always keep some cut offs to use for making small pieces (use a sled) and then either sand or use a small hammer to fit to the gap. Glue is typically stronger then wood so the only issure on a wood shim is that the shim my split at the glue line. Make sure the grain direction of the filler matches that of the item being filled.
View Lee Barker's profile
Lee Barker
1887 posts in 1019 days
#14 posted 604 days ago
Let me see if I can complicate this even further.
It appears that adding a shim is the winnah. And I like the various ideas for being prepared by making shim stock as you go. This procedure has the added benefit of creating an atmosphere where the potential error is already, in one’s mind, taken care of—hence a more peaceful approach and, likely, fewer opportunities to use the shims!
I’m with cr1: construction adhesive is a completely different animal, and not the right choice here.
I disagree with reggie. Epoxy in a trapped joint like MT is gong to be fine, perhaps even superior. It has the added benefit of sticking equally well to endgrain, so your total glue surface, application thickness being optimal, is greater than with wood glue. And epoxy fills voids and adheres to both surfaces. Just mix it very well, at least a minute, and beware the drug store brands.
Finally, the OP says it’s a storage bench, so I’m not envisioning any powerful racking forces wanting to make it go south, so I’d say there’s no need to lose sleep over this. Just shave the falldown and tap ‘er in with some Titebond intimately involved.
Kindly,
View SouthpawCA's profile
SouthpawCA
237 posts in 1401 days
#15 posted 604 days ago
What I’ve done with excellent success is to plane off, from a piece of scrap stock of the same wood, a shaving close to what you think you’ll need. Then glue it to the tenon in the grain direction. Let it harden. Try it again and if still loose repeat. If too thick you can remove some with sandpaper or use a plane to take a very thin shaving. others have recommended this plan of action which is totally better then trying to fill. It with glue.
-- Don
