Would this work? Bearing on router bit.
Forum topic by Cornductor posted 09-24-2011 09:30 PM 1225 views 0 times favorited 7 replies Add to Favorites Watch
View Cornductor's profile
Cornductor
208 posts in 2577 days
09-24-2011 09:30 PM
Topic tags/keywords: question router shaping
So here’s my plan. I made a small jig about 5×5 with smooth curves for my router. I bought some carpet tape to secure my jig to my project. Here is where I hit the stumbling block can I buy an aftermarket bearing that’ll fit the router bit. A bearing that will slip over the shaft and stay secure while in use. I have looked at Mcfeelys and other places but I don’t see how the bearing will stay in place while routing. I guess I’m confused on this and if its even possible. thanks
-- An investment in knowledge pays the best interest. Benjamin Franklin
7 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2486 days
#1 posted 09-24-2011 09:52 PM
You can; you need a bearing with a diameter of the shank of the router bit you’re using, a stop collar the same size and the bit’s cutting diameter has to be bigger than the shank.
It’s how pattern bits are put together.
View ,'s profile
2387 posts in 3456 days
#2 posted 09-24-2011 10:24 PM
Maybe a bushing that slides over the router bit.
View ajosephg's profile
ajosephg
1880 posts in 3471 days
#3 posted 09-25-2011 12:14 AM
Why not just buy a pattern bit?
-- Joe
View WayneC's profile
WayneC
13751 posts in 4007 days
#4 posted 09-25-2011 01:05 AM
http://www.rockler.com/product.cfm?page=19519
View Howie's profile
Howie
2656 posts in 2832 days
#5 posted 09-25-2011 01:18 AM
Check MLCS
-- Life is good.
Cornductor
#6 posted 09-25-2011 03:46 AM
Joe- I did look at pattern bits but I could not find one that was in the v shape. I may not have looked long enough but if you know of any please let me know.
Wayne- that seems to be my next best thing, I’ll probably just buy the bit and then use the collar and bearing on my pattern bit to achieve this.
ajosephg
#7 posted 09-25-2011 05:12 AM
Didn’t know what kind of profile you were looking for, and still not exactly sure.
I like Whiteside bits. Here is a link to their catalog. http://www.whitesiderouterbits.com/catalog.html
You might look at the V Groove Flush Trim Bit.
-- Joe
